December 10, 2017, 09:03 |
MultiRegion snappyHexMesh
SSA
Rep Power: 9 |
Hi all,
I have three regions in my block mesh 1. Region bounded by blockmesh 2. Region named box - searchablebox 3. A ship as an stl file. When I keep the locationinmesh point in the 1.region both 2 and 3 goes off. When I keep the locationinmesh point in the 2.region both 1 and 3 goes off. When I keep the locationinmesh point in the 3.region both 1 and 2 goes off. But I want a mesh with both Region 1 and Region 2 and the ship should be removed, so that I can analyse the flow of water around the ship. And I am not able to keep two locationinmesh points. How to achieve this.? Thanks, Senthil. |
December 29, 2017, 10:10 |
Peter Hess
Rep Power: 17 |
Hello senthilathiban,
- Do the both Mesh-regions you want to keep have a contact/interface with each other? If not, the walking-on-Mesh step during snappyHexMesh will not discover both! - blockMesh must include all regions! The parts outside the Mesh generated by blockMesh will not be recognized by snappyHexMesh! - Did you defined the regionProperties dictionary in constant? I belive you must! see tutorial multiRegionHeater for more informations. Regards Peter Last edited by peterhess; December 31, 2017 at 15:45. |
locationinmesh, multiregion, multiregion meshing, ship flow, snappyhexmesh |
[snappyHexMesh] Multiregion snappyhexmesh | obiscolly50 | OpenFOAM Meshing & Mesh Conversion | 0 | April 18, 2019 01:51 |
[snappyHexMesh] Unzoned cells by SnappyHexMesh for a Multiregion Mesh | mujika | OpenFOAM Meshing & Mesh Conversion | 5 | February 14, 2018 15:38 |
snappyHexMesh axisymmetric multiRegion | Henning86 | OpenFOAM Running, Solving & CFD | 0 | October 23, 2014 13:05 |
[snappyHexMesh] SnappyHexMesh and MultiRegion - get regions from Salome to OF | dzi | OpenFOAM Meshing & Mesh Conversion | 2 | September 4, 2014 11:04 |
Simulation of SnappyHexMesh multiregion | nithishgupta | OpenFOAM Running, Solving & CFD | 0 | June 24, 2014 06:31 |
