[Gmsh] Using Gmsh, must have "faceZone" for fvOptions |
November 21, 2017, 08:17 |
Anders Utnes
Rep Power: 9 |
Hi
Im using fvOptions, and for one of the options I basically need to specify "faceZone". Its commented "Face zone upstream cell zone". The only set I currently have is a cell set called "internal". Anyone know how to extract the faces I need? I expect the setSet application is usefull here, But I've never used that before, and tutorials doesn't seem to cover this specific problem. |
November 21, 2017, 08:39 |
You can use topoSet utility for your task. There are plenty of examples in tutorials. |
[swak4Foam] swakExpression on faceZone returns empty field for non-empty zone | jgross | OpenFOAM Post-Processing | 1 | July 7, 2022 12:28 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[Gmsh] Converting gmsh to OpenFoam | Friendly | OpenFOAM Meshing & Mesh Conversion | 3 | June 26, 2018 06:46 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
