[snappyHexMesh] SnappyHexMEsh, boundary conditions, STL, failed solver |
November 19, 2017, 02:02 |
claude
Hi all
I'm getting started with OpenFOAM simulation and as a test project i tried to simulate the flow through a nozzle. Realistic/Correct results are not necessarily my main priority at the moment, but i'd like to get a simulation going at least. This project will be the base for other similar projects, so I'd like to get the method down. I did the following: 1)Create model ind 3D CAD 2)Export STL with multiple regions 3)SnappyHexMesh the STL 4)copy an icoFoam tutorial and adapt it to my problem 5)try to simulate -> Fail after just a few steps can someone look at my files and tell me where im going wrong? I've varied input velocity, as well as timestep size and still no success, so im assuming the error is deeper, for example in my mesh, but i don't know what to do. Regards Claude PS. My file (2MB) exceeds the forum limit, so i've just uploaded a few of the files i find important. let me know if somethings missing |
November 25, 2017, 06:26 |
Rep Power: 11 |
Hi, could you provide a log file of your simulation ?
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 17:08 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 12:14 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
