[snappyHexMesh] Contact Prevention in SnappyHexMesh |
November 16, 2017, 05:32 |
Oliver Herz
Hi!
Is there an option for a kind of contact prevention in snappyHexMesh? In Order to prevent local non-manifolds between two boundaries, that a near to each other (although the mesh refinement level should be fine enough to get at least one cell between the boundaries)? Best Regards herz.o |
November 16, 2017, 06:12 |
Anton Kidess
Rep Power: 30 |
Have SHM refine additionally in tight gaps (gapRefinementLevel or a similar keyword).
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
Dynamic contact angle | rmousavibt | Fluent UDF and Scheme Programming | 12 | October 31, 2021 23:38 |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 03:39 |
Urgent Help: Surface Wrapper & Contact Prevention (Crashes using more than one CP) | AndreP | STAR-CCM+ | 7 | August 2, 2018 08:04 |
can anyone help me about the udf of dynamic contact angle in FLUENT? | Albert Lee | FLUENT | 0 | July 1, 2018 09:21 |
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 14:58 |
