[Commercial meshers] OpenFoam Mesh to Fluent Mesh in parallel case
Old   November 14, 2017, 03:13
Default OpenFoam Mesh to Fluent Mesh in parallel case
Dominic
DominicTNC is on a distinguished road
Dear all,
I have run an openFoam case simulation, I would like to convert The openFoam mesh into Fluent Mesh so that I can run the simulation again using the same geometry in Fluent. I expected that the OpenFoam utility "foamMeshToFluent" can do the conversion. However, I have run my OpenFoam case using 256 processors and this utility cannot be run with a "-parallel" option.
So what should I do now? How to convert my OF mesh into Fluent mesh for parallel case?
Any comments are appreciated! Thank you.
Regards,
Dominic
DominicTNC is offline   Reply With Quote
Old   November 21, 2017, 04:42
Ayush Agrawal
ayushmorx is on a distinguished road
Your mesh, if you made it in OF, is defined by your blockDict or related file. If so, you can just get the mesh in the system folder, the processor folders just have processor decomposed meshes. You can just run foamMesh... without the parallel option.
If that doesnt work, do reconstructPar for the first few calculated time steps, and then use the mesh conversion utility.
Lemme know if it works?
ayushmorx is offline   Reply With Quote
Old   November 22, 2017, 04:06
Dominic
Thank you for your help.
If I go into the processor files and run the mesh conversion utility individually, it works. However, how can I use these decomposed *.msh files in Fluent?
My case is quite large, so reconstructPar cannot be used since it needs too much rams and the reconstructPar utility cannot be run in parallel.
Old   November 22, 2017, 10:19
Ayush Agrawal
Oh just run foamMeshToFluent in the base directory, no need to go into the processor folders. Without the -parallel option. It should fetch the mesh and convert it to fluent.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
[Commercial meshers] case File with a polyhedral mesh to OpenFoam Christoph_84 OpenFOAM Meshing & Mesh Conversion 2 April 26, 2013 11:07
Comparison of axisymmetric case, Starccm+ and OpenFOAM linnemann OpenFOAM Running, Solving & CFD 12 June 16, 2011 06:43
