[blockMesh] blockMesh runs Indefinitely
Old   October 31, 2017, 08:38
Default blockMesh runs Indefinitely
Shafik Walakaka
walakaka is on a distinguished road
Update[Solved]: I found out that the issue was completely unrelated to the OpenFOAM software. I did not request enough memory from the remote cluster system I was operating in. Therefore, the system terminated my simulation when I refined the mesh as it requires a higher memory.
Thanks!
Hi there, sorry if this is a basic question. I am unable to find a thread that could help me with the following issue.
My blockMesh runs indefinitely when I try to refine my mesh given in the image below.
The blockMeshDict file is the file that is performing fine.
blockMeshDict.txt
The blockMeshDict_err file is the refined mesh that runs indefinitely when i increased the number meshes in the y and z direction.
blockMeshDict_err.txt
Could someone advise me on this matter please?
Thank you in advance!
Shaq
Last edited by walakaka; November 2, 2017 at 04:21. Reason: Issue not related to OpenFOAM [Solved]
walakaka is offline   Reply With Quote
Old   December 29, 2017, 10:40
Peter Hess
peterhess is on a distinguished road
Hello walakaka!
I tried your blockMeshDict using the tutorial cavity and replacing the blockMeshDict with yours.
It works and generates the Mesh fine!
The Mesh has exactly 1400000 cells.
Really much
Do your PC have sufficent Memory?
Maybe it is Hardware problem?
Regards
Peter
peterhess is offline   Reply With Quote
block mesh, cfd
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 20:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 15:54
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 09:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 12:59
