[blockMesh] Generating blockMesh for modified Bubble Column |
October 29, 2017, 14:17 |
Anonymous
Hi!
I have become familiar with the OpenFOAM multiphaseEulerFoam solver and now I am trying to modify the geometries so that I can model the same on an equipment of my design. I was trying to model bubble column as shown in the figure. The inlet is from the (8 9 10 11) and the exit is from the entire opposite face. However I am getting the errors:- permission denied/Fatal Error: Cannot Open Files and some other error also saying (when tried in a different way) that vertices unassigned. The code:- Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; vertices ( (0 0 0) //0 (20 0 0) //1 (20 20 0) //2 (0 20 0) //3 (0 0 90) //4 (20 0 90) //5 (20 20 90) //6 (0 20 90) //7 (9 9 0) //8 (11 9 0) //9 (11 11 0) //10 (9 11 0) //11 (9 9 90) //12 (11 9 90) //13 (11 11 90) //14 (9 11 90) //15 ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 90) simpleGrading (1 1 1) hex (0 1 9 8 4 5 13 12) (20 20 900) simpleGrading (1 1 1) hex (1 2 10 9 5 6 14 13) (20 20 900) simpleGrading (1 1 1) hex (2 3 11 10 6 7 15 14) (20 20 900) simpleGrading (1 1 1) hex (3 0 8 11 7 4 12 15) (20 20 900) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (2 2 900) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (8 9 10 11) ) patch outlet ( (12 13 14 15) (4 5 13 12) (5 6 14 13) (6 7 15 14) (7 4 12 15) ) wall walls ( (0 4 7 3) (2 6 5 1) (0 1 5 4) (2 3 7 6) ) empty ( (0 1 9 8) (1 2 10 9) (2 3 11 10) (3 0 8 11) ) ); mergePatchPairs ( ); // ************************************************************************* // |
December 29, 2017, 04:17 |
Chris
Rep Power: 9 |
Dear dashsubhankar,
your block assignment seems to be the problem..... Your first block is already the hole domain. You need to make nine blocks, i.e. Code:
convertToMeters 0.01; vertices ( (0 0 0) //0 (20 0 0) //1 (20 20 0) //2 (0 20 0) //3 (0 0 90) //4 (20 0 90) //5 (20 20 90) //6 (0 20 90) //7 (9 9 0) //8 (11 9 0) //9 (11 11 0) //10 (9 11 0) //11 (9 9 90) //12 (11 9 90) //13 (11 11 90) //14 (9 11 90) //15 (9 0 0) //16 (11 0 0) //17 (9 20 0) //18 (11 20 0) //19 (9 0 90) //20 (11 0 90) //21 (9 20 90) //22 (11 20 90) //23 (0 9 0) //24 (0 11 0) //25 (20 9 0) //26 (20 11 0) //27 (0 9 90) //28 (0 11 90) //29 (20 9 90) //30 (20 11 90) //31 ); blocks ( hex (0 16 8 24 4 20 12 28) (20 20 90) simpleGrading (1 1 1) hex (24 8 11 25 28 12 15 29) (20 20 90) simpleGrading (1 1 1) hex (25 11 18 3 29 15 22 7) (20 20 90) simpleGrading (1 1 1) hex (16 17 9 8 20 21 13 12) (20 20 90) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (20 20 90) simpleGrading (1 1 1) hex (11 10 19 18 15 14 23 22) (20 20 90) simpleGrading (1 1 1) //..... ); edges ( ); patches ( patch Inlet ( (9 8 11 10) ) patch Outlet ( (4 20 12 28) (28 12 15 29) (29 15 22 7) (20 21 13 12) (13 14 15 12) (15 14 23 22) ) wall Wall ( (0 16 20 4) (0 4 28 24) (28 29 25 24) (29 7 3 25) (3 7 22 18) (16 17 21 20) (22 23 19 18) ) ); mergePatchPairs ( ); |
Bubble Column Modelling | dlaw | FLUENT | 24 | October 31, 2017 06:01 |
Problem: bubble column with twoPhaseEulerFoam | hester | OpenFOAM Running, Solving & CFD | 6 | January 22, 2016 12:25 |
2D bubble rising through a column of water | vof64 | Fluent Multiphase | 0 | August 19, 2014 23:42 |
bubble column | ken | FLUENT | 1 | June 30, 2013 01:18 |
Doxygen documentation | Tanay | OpenFOAM Installation | 9 | September 23, 2011 11:40 |
