[blockMesh] Problem using C in blockMesh
Old   October 28, 2017, 18:43
Question Problem using C in blockMesh
DeAldeEiam is on a distinguished road
I have a problem with calculated values in my blockMesh file.
I get a value calculated for the amount of cells in a block
e.g. 5.666666666667
but I can only use integer
how can I round up 5.666666666667 to 6 in my blockMesh file?
I know setprecision(0) could work but how can I integrate it?
Thanks a lot
this is an easy example
I get a value calculated for the amound of cells in a block
e.g. 5.666666666667
but I can only use integer6
roundUp 5.666666666667;
vertices
(0 25 10) // pt 0 (a1t)
(20 25 10) // pt 1 (a2t)
(20 3 10) // pt 2 (a3t)
(0 3 10) // pt 3 (a4t)
(0 25 0) // pt 4 (a1b)
(25 25 0) // pt 5 (a2b)
(25 2 0) // pt 6 (a3b)
(0 2 0) // pt 7 (a4b)
blocks
hex (4 7 6 5 0 3 2 1) ( 50 50 $roundUp ) simpleGrading (1 1 1)
DeAldeEiam is offline   Reply With Quote
Old   October 30, 2017, 09:06
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
You have #calc directive, where you can put C++ code. You can find usage examples in tutorials (using grep for example).
alexeym is offline   Reply With Quote
Old   November 7, 2017, 13:23
Default Solved
I found a solution.
You have to add Math::Round - Perl extension for rounding numbers to your calc function.
Explanation:
How to add Cpan Modules
Math::Round function
New calc function:
define(calc, [esyscmd(perl -e 'use Math::Round qw(:all); print ($1)')])
Old   November 7, 2017, 17:30
Alexey Matveichev
So, you were trying to put this into M4 script.
There is POSIX::floor and POSIX::ceil (POSIX module), which do not require installation of additional modules. I.e. you can use
perl -e 'use POSIX (floor); print floor($1)'
Though, surely you can install additional Perl modules. Or you can even go further and try to round numbers with Smalltalk.
[snappyHexMesh] Problem and doubts with blockMesh, snappyHexMesh and multiple geometry luca1992 OpenFOAM Meshing & Mesh Conversion 0 August 23, 2017 12:40
[blockMesh] BlockMesh problem ari92 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2017 11:23
[blockMesh] blockMesh problem with wedge blocks gned OpenFOAM Meshing & Mesh Conversion 0 September 14, 2016 06:49
[blockMesh] Problem with blockMesh and my shape TneurolF OpenFOAM Meshing & Mesh Conversion 4 June 25, 2013 14:52
Blockmesh problem with more than one block sven82 OpenFOAM Pre-Processing 1 June 4, 2013 18:08
