[snappyHexMesh] [Problem] Addlayer worsen Mesh quality
Old   October 25, 2017, 06:16
Unhappy [Problem] Addlayer worsen Mesh quality
Edoardo
edoardo.mancuso1993 is on a distinguished road
Hi guys.
I'm encountering problems with snappyHexMesh. I'm trying to generate the mesh of a centripetal turbine (scroll and impeller).
The snap phase seems ok, the edge are well defined and nothing goes wrong.
But when I try to add the boundary layer cells, the edges of the impeller became really bad.
I've already tried different edge/surface/region refinements as well as different shrinking parameters.
The problem is that the solutor (rhoSimpleFoam) will not do more than 5 iters (I attached the log file).
I'm also sure that the problem are these boundary layer cells in the impeller, since if I do not add here the layers the solutor won't have any issues.
I attach the images of the problem as well as the dictionaries.
I really need help since this is the basis of my master thesis project and it seems I can't find the solution
snappyHexMeshDict.txt
logrhoSimpleFoam.txt
edoardo.mancuso1993 is offline   Reply With Quote
Old   October 26, 2017, 11:27
Pascal Balz
pbalz is on a distinguished road
HI edoardo,
regarding your solver crash: this could either be due to bad boundary conditions or a really bad mesh/wrong fvSchemes. Could you please post the output for
checkMesh -constant -allGeometry
If the solver converges without boundary layers an error in the definition of boundary conditions is more unlikely.
Layer generation with snappyHexMesh is really a pain in the ass for propeller geometries. The edges will most times look like yours and layers will likely collapse at the trailing edge. Thats due to the algorithm and I don't know a solution to that.
What you should do:
- post the log file of snappyHexMesh so that we can see whats going on there
- some changes in snappyHexMeshDict:
maxLocalCells: highly increase this value as it will likely stop any refinement steps and layer additions.
maxGlobalCells: increase this one too.
nCellsBetweenLevels: 3 or more.
nLayerIter: increase this value up to 200, start with 50
Most likely your mesh quality settings are to strict for generating the layers.
Try setting the following values:
maxNonOrtho 75;
maxInternalSkewness 10;
maxConcave 180;
minVol 1e-20;
minTetQuality -1e30;
minTwist -1;
This should generate at least a few layers.
Regards,
Pascal
pbalz is offline   Reply With Quote
addlayers, addlayerscontrols, snappy, snappyhex, snappyhexmesh
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[snappyHexMesh] Improving mesh quality + inlet too coarse MartinBlx OpenFOAM Meshing & Mesh Conversion 5 August 2, 2015 23:09
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
