[Other] Super simple mesh, Failed mesh check
Old   October 15, 2017, 15:39
Default Super simple mesh, Failed mesh check
Marius Lang
Ursmooth is on a distinguished road
Hello I want to make a O grid mesh with a cylinder in the middel, the O grid is made up by 4 parts. I am trying to make the first part, but I get a failed mesh check, can somebody help me? And explain whats going wrong?
| \\ / O peration | Version: 4.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 10 -0.5) //0
(0 1 -0.5) //1
(1 0 -0.5) //2
(10 0 -0.5) //3
(0 10 0.5) //4
(0 1 0.5) //5
(1 0 0.5) //6
(10 0 0.5) //7
blocks
hex (2 3 0 1 6 7 4 5) (5 5 1) simpleGrading (1 1 1)
edges
patches
mergePatchPairs
File Type: jpg Screen Shot 2017-10-15 at 20.37.37.jpg (160.2 KB, 7 views)
Ursmooth is offline   Reply With Quote
Old   October 15, 2017, 22:23
Antimony is on a distinguished road
Your mesh, at least from the checkMesh log, is perfectly fine.
The "errors" that you see are because you have not defined any patches in the blockMeshDict. As a result, for the moment, OF does not know what type of simulation yours is going to be - 1D, 2D or 3D
Once you define the different patches in blockMeshDict (including giving them a type), you will see that this "error" goes away.
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   October 16, 2017, 05:58
Marius Lang
Thank you Antimony!
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
Mesh check failed: 1 cells have only wall faces. sugar678513 FLUENT 1 May 5, 2022 19:13
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[ICEM] mesh check failed RAJ KIRAN ANSYS Meshing & Geometry 6 January 24, 2013 02:05
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
