[Commercial meshers] SolidWorks to ANSYS to OpenFoam mesh conversion failed
Old   October 4, 2017, 07:53
Unhappy SolidWorks to ANSYS to OpenFoam mesh conversion failed
Swapnil P
nuclear_swapnil is on a distinguished road
Hey Foamers!!!!!
I have been stuck at mesh conversion problem since long... Kindly help me to understand the problem.
I am trying to simulate a stirred tank reactor in OpenFOAM using MRFProperties.
I have modeled the geometry in solidworks and imported to ansys mesh tool where I have done the meshing. However, when I try to convert the .msh file to foam file using fluentMeshToFoam <filename>.msh, I get the following error.
Embedded blocks in comment or unknown: (
Found end of section in unknown
number of faces: 135368
Number of cells: 61069
Reading points
Reading points
Reading mixed faces
Reading uniform faces
Reading mixed faces
Other readCellGroupData: 2 1 ee8d 1 0
Reading mixed cells
Read zone1:1 name:interior-geom_solid1 patchTypeID:interior
Reading zone data
Read zone1:2 name:geom_solid1 patchTypeID:fluid
Reading zone data
Read zone1:5 name:rotor patchTypeID:wall
Reading zone data
Read zone1:6 name:wall patchTypeID:wall
Reading zone data
Read zone1:7 name:wall1 patchTypeID:wall
Reading zone data
FINISHED LEXING
dimension of grid: 3
Creating shapes for 3-D cells
Building patch-less mesh...--> FOAM Warning :
From function Foam:olyMesh:olyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const cellShapeList&, const faceListList&, const wordList&, const wordList&, const Foam::word&, const Foam::word&, const wordList&, bool)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595
Found 5620 undefined faces in mesh; adding to default patch.
done.
Building boundary and internal patches.
Creating patch 0 for zone: 1 start: 1 end: 129748 type: interior name: interior-geom_solid1
Creating patch 1 for zone: 5 start: 129749 end: 132606 type: wall name: rotor
Creating patch 2 for zone: 6 start: 132607 end: 133916 type: wall name: wall
Creating patch 3 for zone: 7 start: 133917 end: 135368 type: wall name: wall1
Patch interior-geom_solid1 is internal to the mesh and is not being added to the boundary.
Adding new patch rotor of type wall as patch 0
Adding new patch wall of type wall as patch 1
Adding new patch wall1 of type wall as patch 2
Writing mesh... to "constant/polyMesh" done.
End
I know the error is due to generated Patch "interior-geom_solid1" which I have not generated. Herewith I have attached .msh file. kindly help me to understand the problem. Exactly where I am doing mistake (in ANSYS or solidworks)
nuclear_swapnil is offline   Reply With Quote
Old   October 11, 2017, 01:38
M. C.
student666 is on a distinguished road
If you're runningun a 3D case,
The proper command is fluent3dMeshToFoam
student666 is offline   Reply With Quote
fluent, fluentmeshtofoam, solidworks
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
[Commercial meshers] Mesh conversion .gtm to OpenFOAM ansab OpenFOAM Meshing & Mesh Conversion 2 December 6, 2016 14:48
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
[Commercial meshers] Mesh conversion from Ansys ICEM fabian_korn OpenFOAM Meshing & Mesh Conversion 3 February 24, 2010 09:19
