[blockMesh] meshing a rectangular prism surrounded by a circumference |
September 20, 2017, 06:20 |
Rep Power: 9 |
I am a BEng student and I am using OpenFoam 3.0.1 to study the movement of a floating rectangular prism that is capsizing. I would like to study the waves produced by just the capsizing of the block. My problem is a two dimensional case in the x-y plane. I used blockMesh to generate a rectangular prism surrounded by a circumference. At first the centre of the circle (Xc;Yc) coincides with the centre of gravity G(Xg; Yg) of the rectangular prism and I didn't have any problem to generate the mesh. However, I noticed that if the level of the free surface (Ywater) didn't coincide with the Yc (that in this case was Yg) , OpenFoam couldn't generate a good free surface. So, I'm trying to change the mesh. The new centre of the circle should be (Xc; Ywater), but blockMesh doesn’t generate a good mesh into the circumference. In my log.blockMesh there is this warning --> FOAM Warning : From function polyMesh:: polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 901 Found 18 undefined faces in mesh; adding to default patch. Is it possible that the rectangular prism must be in the centre of the circumference? I would really appreciate some advice on this. Thanks in advance for any help. Last edited by maram; September 27, 2017 at 11:57. |
ICEM - problems with prism mesh | João Lourenço | CFX | 2 | September 18, 2019 04:07 |
[ICEM] Meshing over rectangular slab with different material conducitivity material embedded | Dinesh Yadav | ANSYS Meshing & Geometry | 1 | September 24, 2013 12:06 |
[ANSYS Meshing] Meshing for T shaped Rectangular duct | Bhargav93 | ANSYS Meshing & Geometry | 0 | June 25, 2013 08:22 |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 08:06 |
Icemcfd: Preventing prism inflation collisions? | Joe | CFX | 1 | July 31, 2007 10:13 |
