[snappyHexMesh] How to calculate a Volume of all Cells after using snappyHexMesh
Old   August 19, 2017, 17:21
Exclamation How to calculate a Volume of all Cells after using snappyHexMesh
Joaquin Del Pino
joaquindelpino is on a distinguished road
Hello everyone.
I'm simulating a bio-filter inside of a room.
To generate mesh I used snappyHexMesh. Then I runed the simulation using simpleFoam and I got the velocity and pressure in each cell, but now I need to compute the volume of each cell to calculate the % of volume in that velocity is different from zero.
I read a lot of topics in CFD but i don't understand where I must be create codes or use mesh.V().
I would appreciate a detailed explanation
Regards.
Joaquin Del Pino
joaquindelpino is offline   Reply With Quote
Old   August 21, 2017, 05:56
Mikko
Flowkersma is on a distinguished road
Hi Joaquin,
Can you use ParaView (paraFoam)?
Following filters in ParaView should do what you want:
1. Use Calculator filter to calculate the scalar of interest (mag(U)).
2. Use Clip filter to extract the volume of interest. Choose ClipType=Scalar, Scalars=magU and choose a delimit value for the velocity.
3. Use IntegrateVariables filter to calculate the volume. Choose attribute=Cell Data and then you should see a column with volume.
Best,
Mikko
Flowkersma is offline   Reply With Quote
Old   August 21, 2017, 09:08
Joaquin Del Pino
Originally Posted by Flowkersma View Post
Hi Joaquin,
Best,
Mikko
Thx Mikko, I really appreciate your answer. But I have some questions,
1. In calculator filter, I have 2 options, scalar and volume. In scalar appears: p, U_x, U_y, U_z. In vectors appears: U. Wich one I need? ((U_X)^2)+((U_Y)^2)+((U_Z)^2)^(1/2) ? That's correct?
2. In calculator filter mag(U) is the result array name?
3. In the delimit value for the velocity, I need the volume of cells in wich velocity is greater than 0.0001, this is my delimit value?
4. In integrateVariables filter show only one cell data, that's right?
Regards.
Old   August 21, 2017, 11:03
Mikko
Hi Joaquin,
1. and 2. In Calculator you can specify the result array name. By default it is "Result". In the next field you define your function which is for velocity magnitude either "mag(U)" or "((U_X)^2)+((U_Y)^2)+((U_Z)^2)^(1/2)". Change the "Attribute Mode" to "Cell Data" if you want to extract only the cells. If you want a "smooth" surface at the interface then use "Point Data". ParaView will then automatically create a smooth interface with refined mesh and interpolated data.
3. and 4. that is right.
Old   August 21, 2017, 11:15
Joaquin Del Pino
Ok, thank you for all your replies, there are very helpful.
Regards
cell, cellvolume, mesh.v(), snappyhexmesh, volume
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
cellZone not taking all the cells inside rahulksoni OpenFOAM Running, Solving & CFD 6 January 25, 2019 01:11
cellZone not taking all the cells inside rahulksoni OpenFOAM 0 January 16, 2019 02:16
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
