[Gmsh] GMSH: Meshing a cylinder with a HUGE number of points
Old   August 9, 2017, 16:44
Question GMSH: Meshing a cylinder with a HUGE number of points
Marc
HelplessWanderer is on a distinguished road
Hi folks,
I need to mesh a cylinder with a VERY FINE mesh.
Point(1) = {0,0,0,0.01};
Point(2) = {0.012,0,0,0.001};
Point(3) = {0,0.012,0,0.001};
Point(4) = {-0.012,0,0,0.001};
Point(5) = {0,-0.012,0,0.001};
Circle(1) = {2,1,3};
Circle(2) = {3,1,4};
Circle(3) = {4,1,5};
Circle(4) = {5,1,2};
Line Loop(5) = {1,2,3,4};
Plane Surface(6) = {5};
Extrude {0,0,0.040} {
Surface{6};
Unfortunately, that doesn't work at all. After I have created a 2D-meshing, the 3D-meshing gets stuck, probably because there are really too many points.
Is there a way to surmount this problem?
Many thanks in advance.
HelplessWanderer is offline   Reply With Quote
Old   August 10, 2017, 15:17
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
1. What Gmsh version do you use? 3.0.1 generates mesh quite easily, and the mesh is not so fine. Also what mesh generators are in your settings?
2. Do you really want coarser mesh near point 1 or it is just typo?
alexeym is offline   Reply With Quote
parallel run OpenFoam Srinath Reddy OpenFOAM Running, Solving & CFD 13 February 27, 2019 10:15
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
