[Other] Meshing sharp edges
Old   August 9, 2017, 05:20
Default Meshing sharp edges
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
Hello everyone,
I know this is a very common problem but I haven't found a solution yet.
I have a geometry with some sharp edges that will definitely produce skewed cells.
What can I do to make a good mesh? It's a rather simple pump impeller that's connected to volute with ACMI. I can't change the geometry because that would mean I'm running a case of a different thing...
See the troublesome spots in attachment.
Thanks!
kandelabr is offline   Reply With Quote
Old   August 25, 2017, 10:02
kandelabr's Avatar
Nejc
*Ahem*...
Does anyone have any experience with that? How does one mesh an impeller? Do thin and long boundary layer cells help?
If I was meshing this manually (with a tool I do not know yet ), I would just extrude boundary layers until they all met in the middle.
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
[ICEM] How to create prism layers on sharp trailing edges in ICEM CFD (3D Tetra Mesh)? waseeqsiddiqui ANSYS Meshing & Geometry 15 January 30, 2019 11:59
[ANSYS Meshing] Reducing mesh non-orthognality for bluff body with sharp edges Bashar ANSYS Meshing & Geometry 2 November 18, 2016 03:28
[ICEM] Meshing Wing with low Y+ value and sharp trailing edge sonic109 ANSYS Meshing & Geometry 0 July 27, 2015 10:29
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
