[mesh manipulation] refineMesh: command not found
Old   August 5, 2017, 13:15
Default refineMesh: command not found
bar
Bartlomiej
bar is on a distinguished road
Hi
I have got a problem. When I want to use commad: refineMesh, it appear: "refineMesh: command not found". Could anybody help me?
bar is offline   Reply With Quote
Old   August 6, 2017, 11:29
bar
Bartlomiej
I found solution. I had to compile files again. If someone wants to know how to do it - here is answer:
https://www.cfd-online.com/Forums/op...not-found.html
I close the topic
command, not found, refine mesh
[Gmsh] Insatlling gmsh from the source code-issue? CFD-Lover OpenFOAM Meshing & Mesh Conversion 20 June 12, 2018 07:39
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 16:11
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 02:36
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
