[snappyHexMesh] Create Cylinder (HOLLOW NO MESH OR CAVITY) inside a Cuboid |
sandy
Rep Power: 10 ![]() |
hello foamers
i have an interesting problem to discuss with you all. 1. i am having a cuboid of 10 cmx 10 cmx 10cm...which i can easily make in blockmesh. 2. i have to create a cylinder which lies entirely inside the cuboid close to the bottom. its dia is 1 cm and length 6 cm so it lies inside the cuboid. 3.i have to give boundary condition to this cylinder surface. so its a wall here how do i delete the mesh of this cylinder, the cylinder is not supposed to have mesh inside how do i define a patch of cylindrical surface, so i can give bc in 0 folder the issue is: i cannot do so using blockmesh which is very tiring and prone to mistakes i am trying to use cell set by deleting the cells using cylinder to cell and define a patch using cylinder to cell but i don't know exactly how to write this procedure using toposet dict please help me foamers i really need to get this done |
sandy
i'm so glad i did it...
however i ran into another minute issue when i create the cylinder the mesh around it is irregular and nott a perfect circle. how ca i smooth these faces to get the smooth circle...not exactly..but how can i improve this?? collapse edges or what?? image is attached here |
sandy
i tried more refinement but still the circumference of circle contues to be irregular
my conclusion is: it can't be done using refinement or toposet or blockmesh only way is use .stl file of cylinder inside a cuboid next use snapphexmesh to get the job done will keept his thread updated |
Rep Power: 16 ![]() |
If you know there is going to be cylinder in your geometry, then you can use blockMesh to create a mesh that has a cylinder. That way you can avoid the issue with irregular cells. Cheers, Antimony |
#5 | |
sandy
i am thinking about using snappy hex mesh using .stl file if u have any simple beginner tutorials using a cylinder, could you point me in that direction??? |
Atefeh T
Rep Power: 3 ![]() |
Hi, can you please explain how did you extract the mesh inside the cylinder from your general mesh?
cellsets, cylinder domain, mesh manipulation, toposetdict |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
Mesh type in rotating blade inside cylinder | Mah.tavana | Mesh Generation & Pre-Processing | 0 | July 26, 2014 06:53 |
[ANSYS Meshing] Meshing Strategy for inside geometry | powpow | ANSYS Meshing & Geometry | 6 | January 16, 2013 04:32 |
How do I create a simple cylinder with a mesh | s_lab | FLUENT | 1 | January 27, 2011 02:08 |
