[snappyHexMesh] Layers collapsing
Old   July 10, 2017, 06:11
Default Layers collapsing
max.pow is on a distinguished road
Hello foamers,
for my thesis I'm currently working on a simulation of the NASA CRM model (https://commonresearchmodel.larc.nasa.gov/).
I'm trying to create the mesh using snappyHexMesh. For reaching my yPlus values, I have to add Layers, but there seems to be some problems with snappyHexMesh:
The layers collapse before they reach the tip of the leading edge. I've tried to vary the addLayersControls in my snappyHexMeshDict, with no better results than in the attached screenshot.
Here you can see my snappyHexMeshDict:
FoamFile
version 2.0;
format ascii;
class dictionary;
location system;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers true;
geometry
plane.stl
type triSurfaceMesh;
name plane;
refinementFar
type searchableCylinder;
point1 (-100 0 5 );
point2 (200 0 5);
radius 100;
refinementFuselage
point1 (-1 0 5 );
point2 (68 0 5);
radius 10;
refinementWing
point1 (30 0 5 );
point2 (48 31 7);
radius 7;
refinementHTP
point1 (60 0 6 );
point2 (65 15 8);
radius 4;
refinementLE1
point1 (25.22 3.05 4.47 );
point2 (31.1135 10.871 4.599);
radius 0.3;
refinementLE2
point1 (31.1135 10.871 4.599);
point2 (38.019 19.9 5.279);
radius 0.3;
refinementLE3
point1 (38.019 19.9 5.279);
point2 (42.06751 25.227 6.011);
radius 0.3;
refinementLE4
point1 (42.06751 25.227 6.011 );
point2 (45.27 29.4 6.7);
radius 0.3;
castellatedMeshControls
features
file "plane.eMesh";
level 5;
refinementSurfaces
plane
level ( 9 9 );
patchInfo
type wall;
inGroups (planeGroup);
refinementRegions
plane
mode distance;
levels (( 0.002 9 ) ( 0.05 8 ) ( 0.1 7 ));
refinementFar
mode inside;
levels ((1E15 2));
refinementFuselage
mode inside;
levels ((1E15 6));
refinementWing
mode inside;
levels ((1E15 6));
refinementHTP
mode inside;
levels ((1E15 6));
refinementLE1
mode inside;
levels ((1E15 10));
refinementLE2
mode inside;
levels ((1E15 10));
refinementLE3
mode inside;
levels ((1E15 10));
refinementLE4
mode inside;
levels ((1E15 10));
locationInMesh (-400.0 50.0 -400.0 );
maxLocalCells 10000000;
maxGlobalCells 200000000;
minRefinementCells 2;
nCellsBetweenLevels 3;
resolveFeatureAngle 30.0;
allowFreeStandingZoneFaces true;
planarAngle 30.0;
maxLoadUnbalance 0.01; //was 0.1
snapControls
nSolveIter 100;
nSmoothPatch 5;
tolerance 2.0;
nRelaxIter 5;
nFeatureSnapIter 10;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap false;
addLayersControls
layers
plane
nSurfaceLayers 15;//was 15
expansionRatio 1.1; //was 1.25
finalLayerThickness 0.01;
minThickness 1.0E-6;
meshShrinker displacementMotionSolver;
solver displacementLaplacian;
displacementLaplacianCoeffs
diffusivity quadratic inverseDistance 1(plane);
relativeSizes false;
expansionRatio 1.25;
minThickness 1e-06;
nGrow 0; //was 0
featureAngle 60.0; //was 120
slipFeatureAngle 30.0;
nRelaxIter 5;
nSmoothSurfaceNormals 1;
nSmoothNormals 5;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5; // was 0.5;
maxThicknessToMedialRatio 0.3; // was 0.3
minMedialAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
nRelaxedIter 20;
nMedialAxisIter 10;
nSmoothDisplacement 90;
detectExtrusionIsland true;
mergePatchFacesAngle 45;
meshQualityControls
maxNonOrtho 65.0;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 70.0;
minFlatness 0.5;
minVol 1.0E-13;
minTetQuality 1.0E-15; //was 1.0E-15
minArea -1.0;
minTwist 0.02;
minDeterminant 0.001; // was 0.001
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1.0;
nSmoothScale 4;
errorReduction 0.65;
relaxed
maxNonOrtho 75;
debug 0;
mergeTolerance 1.0E-6;
autoBlockMesh false;
Is there any possiblity to avoid collapsing layers?
Thanks for your help,
Max
max.pow is offline   Reply With Quote
Old   July 10, 2017, 08:51
sati is on a distinguished road
Snappy doesn't work well when the size difference between the last cell of the boundary layer and the first cell of the rest of your mesh is too high.
Try to refine a bit more the cells close to the geometry, and it should be ok.
sati is offline   Reply With Quote
Old   July 10, 2017, 11:59
hokhay is on a distinguished road
Try to set featureAngle in addLayersControl to 180
Sent from my LG-H818 using CFD Online Forum mobile app
hokhay is offline   Reply With Quote
Old   July 24, 2017, 08:53
benoit paillard
bennn is on a distinguished road
Try cfmesh. It'll work, guaranteed
bennn is offline   Reply With Quote
Old   August 14, 2017, 18:47
me3840 is on a distinguished road
I would not use CfMesh for this, it doesn't really make good prism layers. For a very boundary layer dominated problem like this it's better to go with the better prism generator (albeit more frustrating..)
me3840 is offline   Reply With Quote
Old   August 15, 2017, 05:05
benoit paillard
My experience is exactly the opposite of what you're saying, but I would be very curious to see examples... thanks !
Old   October 15, 2021, 06:54
Supakorn Suttiruang
cosmictrex is on a distinguished road
Have you been able to successfully generate a good CRM mesh with either snappy or cfMesh? I'm starting to be curious if this is possible at all. One report from the AIAA Drag Prediction Workshop even mentioned that "snappyHexMesh is too poor" for even the coarsest mesh requirement.
cosmictrex is offline   Reply With Quote
[snappyHexMesh] Collapsing layers RomCFD OpenFOAM Meshing & Mesh Conversion 5 January 18, 2020 02:39
[snappyHexMesh] Collapsing layers michi.ka OpenFOAM Meshing & Mesh Conversion 6 September 22, 2018 10:20
[snappyHexMesh] Layers collapsing problem Manideep Reddy OpenFOAM Meshing & Mesh Conversion 2 March 12, 2018 08:09
[snappyHexMesh] SHM addLayers problem: boundary layers collapsing on a patch DOFuser OpenFOAM Meshing & Mesh Conversion 1 October 22, 2015 09:09
[snappyHexMesh] Collapsing Layers Tim_Simon OpenFOAM Meshing & Mesh Conversion 5 August 2, 2015 23:51
