[Other] Multiregion Meshing- Interpolation required? |
Ashish Vinayak
Rep Power: 11 ![]() |
Hi everyone,
I have made a multi region mesh in Salome. This implies that I have a solid and fluid region, each having their own mesh resolutions. At the interface though the polyMesh shows the following, implying that the interface has not been mapped yet: Fluid side patch: matl_top { type patch; nFaces 2; startFace 2252; } Solid side patch: matl_top { type patch; nFaces 211; startFace 162155; } I plan to convert to type mappedWall manually (see link). Since nFaces is different on either side, I would require to do some kind of interpolation to get the correct mapping? Or is this directly taken care of by the mappedWall type ? matl_top { type mappedWall; nFaces // different on each side; startFace // different on each side; sampleMode nearestPatchFace; sampleRegion fluid_region; samplePatch matl_top; } Can someone point me in the right direction? Thank you very much ![]() |
mapped boundary condition, meshing, multiregion, openfoam, salome |
Map of this Meshing (sub-)Forum | wyldckat | OpenFOAM Meshing & Mesh Conversion | 0 | April 27, 2019 09:33 |
[ANSYS Meshing] Parallel meshing utilisation failing | crc1622 | ANSYS Meshing & Geometry | 0 | February 14, 2019 02:42 |
[ICEM] ICEM meshing - Tips from forum - Collection | shereez234 | ANSYS Meshing & Geometry | 0 | June 16, 2015 09:47 |
momentum interpolation for collocated grid | Hadian | Main CFD Forum | 4 | December 25, 2009 07:25 |
