July 2, 2017, 05:18 |
blockMesh with internal cavity
Amod Kumar
Rep Power: 16 |
I was trying a simpler geometry to create mesh using blockMesh. Please refer to the two cases. I am able to generate mesh for Case_1 but foam aborts in Case_2. Hopefully a 4-eye review might shed some light on the problem? Thank you and kind regards, Amod |
July 8, 2017, 11:44 |
Amod Kumar
Rep Power: 16 |
Please ignore my previous post. I was checking and re-checking the block definition. But the actual problem was wrong definition of empty patches. Regards, Amod |
blockmesh, bluff body |
[ICEM] Meshing a cavity within an aerofoil | Alwaysabeginner | ANSYS Meshing & Geometry | 5 | August 13, 2022 11:59 |
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores | puneet336 | OpenFOAM Running, Solving & CFD | 11 | April 7, 2019 01:58 |
[blockMesh] blockMesh seems to create internal barriers | bendel_boy | OpenFOAM Meshing & Mesh Conversion | 0 | July 17, 2018 09:58 |
[blockMesh] Creating an internal mesh within blockMesh? | ashish.vinayak | OpenFOAM Meshing & Mesh Conversion | 4 | June 22, 2018 04:42 |
[blockMesh] Unwanted internal Mesh in OpenFOAM, using blockMesh | nitishanand1989 | OpenFOAM Meshing & Mesh Conversion | 1 | November 7, 2015 13:43 |
