[snappyHexMesh] use toposetdict to dlete cylinder from cuboid
Old   June 2, 2017, 09:15
Default use toposetdict to dlete cylinder from cuboid
sandy
saddy is on a distinguished road
hello foamers
i am having interesting problem. i have to create a cuboid geometry with a rod inside the cuboid. the rod is hollow so there is no mesh inside the rod volume. [i have to create a volume mesh minus the volume of rod]
i did this using 5 blocks which together form this geometry and mesh it successfully
but this compromises mesh quality.
i am trying to do this using toposetdict by making a cuboid and then delete from cylinder volume
but i i dont know exacty how to write and implement this strategy....can u please help me guys???
i am attaching my figures below
saddy is offline   Reply With Quote
Old   August 21, 2017, 16:06
sandy
well i tried doing it using toposetdict by following dam break with obstacle steps followed and did it.
hoever the cylinder shape is not cylindrical......alas..all hard work failed. only option is to use snappyhexmeshdict
mesh 3d, mesh manipulation, toposet, toposetdict
[snappyHexMesh] Create Cylinder (HOLLOW NO MESH OR CAVITY) inside a Cuboid saddy OpenFOAM Meshing & Mesh Conversion 5 August 8, 2023 08:10
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 17:16
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Forces Acting on a Rotating Cylinder (Moving Mesh) dreamchaser CFX 5 April 25, 2015 07:01
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 04:56
