[Other] Increasing interface resolution with adaptive meshing
Old   May 2, 2017, 08:38
Default Increasing interface resolution with adaptive meshing
Laura Luhede
LauraL is on a distinguished road
Hi all,
we want to analyse the shear stress at an oil-water interface. For that we use the VOF method coupled with level set. The first validation case showed large gradients at the interface and we need to increase the resolution in the interface area, to get the right shear stress results.
Our approach is to add the dynamic mesh refinement to aour solver. The problem is, that here, while refining the area, the resolution stays constant as the interface layer is reduced, so even with mesh refinement we get the same number of data points (see images of oil drop in water).
Does anyone have an idea how to increase the data points in the interface area?
Second issue is, that the initialization seems to be wrong as we get a SLIC like surface reconstruction instead of PLIC. Does anyone know a reason for that?
What we tried so far:
- Mesh refinement without level set, thin interface still apeared (interDyMFoam / Problem 1)
- Surface reconstruction over time due to interfacial tension, but no perfect sphere reached (Problem 2)
It would be great if someone could give us a hint how to proceed.
Best regards,
Laura
LauraL is offline   Reply With Quote
Old   May 9, 2017, 11:40
Default This website should help you
Phanindra
phani45 is on a distinguished road
http://www.holzmann-cfd.de/index.php...efinefvmesh-en
phani45 is offline   Reply With Quote
interdymfoam, interface, refinement, surface reconstruction
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[ANSYS Meshing] multibody part doesn't shared node in the meshing of interface jason580315 ANSYS Meshing & Geometry 0 March 1, 2017 03:09
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
