April 26, 2017, 12:04 |
Mirror CellZones
Roberto
Rep Power: 10 |
Dear Foamers,
I've been looking for a way to mirror my cellZones. I want to generate a cylinder, however I have just managed to create a veery thin slice of it, if you see the picture below, the red part is my porous medium. The fluid flows from the left to the right and I would like to mirror this slice till I get the full cylinder. However, I realized that when I mirror my mesh the cellZones, in this case porous medium, are not mirrored. Is there somebody who could please give me a hint? I generated the mesh using blockMeshDict and I am trying different ways to obtain this full cylinder with the CellZones, but I am stuck in this part... Thank you!!! Roberto |
September 16, 2022, 11:09 |
Rep Power: 8 |
Hi Roberto, did you or anybody find a solution to that?
I want to mirror a mesh for a multi region case. Mirroring the whole mesh works but I cannot run splitMeshRegions to split the mesh into regions because the cellZones are not mirrored. Thank you, any hints are appreciated. |
September 19, 2022, 11:24 |
Gerhard Holzinger
Rep Power: 28 |
This is actually quite straight forward: loop over your cells belonging to a set or zone, and find its mirror image.
Here's some code, which has last been used using OpenFOAM 6 and/or 7. Note that I will not provide any support. Code:
// mirrorCellSets #include "argList.H" #include "Time.H" #include "volFields.H" #include "plane.H" #include "topoSetSource.H" #include "cellSet.H" #include "faceSet.H" #include "pointSet.H" #include "cellZoneSet.H" #include "IOobjectList.H" #include "SortableList.H" using namespace Foam; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { argList::addBoolOption ( "verbose", "be more talkative" ); argList::addOption ( "dict", "file", "specify alternative dictionary for the mirrorMesh description" ); argList::addOption ( "excludeSet", "name", "exclude the specified cellSet from mirroring" ); #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" const bool verbose = args.optionFound("verbose"); const word dictName("mirrorMeshDict"); fileName dictPath = dictName; // Check if the dictionary is specified on the command-line if (args.optionFound("dict")) { dictPath = args["dict"]; dictPath = ( isDir(dictPath) ? dictPath/dictName : dictPath ); } // read the excludeSetName from command-line word excludeSetName; if (args.optionReadIfPresent("excludeSet", excludeSetName)) { Info<< "Excluding " << excludeSetName << " from mirroring." << nl << endl; } // read mirrorMeshDict and create mirror plane IOdictionary mirrorMeshDict ( IOobject ( dictPath, runTime.system(), mesh, IOobject::MUST_READ_IF_MODIFIED, IOobject::NO_WRITE ) ); plane mirrorPlane(mirrorMeshDict); // get all cell centroid positions const volVectorField& cellCenters(mesh.C()); // Process cell sets Info<< "Listing all cell sets." << endl; // Search for list of objects for the time of the mesh word setsInstance = runTime.findInstance ( polyMesh::meshSubDir/"sets", word::null, IOobject::MUST_READ, mesh.facesInstance() ); IOobjectList objects(mesh, setsInstance, polyMesh::meshSubDir/"sets"); IOobjectList cellObjects(objects.lookupClass(cellSet::typeName)); forAllConstIter(IOobjectList, cellObjects, iter) { // Not in memory. Load it. cellSet set(*iter()); SortableList<label> cellLabels(set.toc()); label zoneID = mesh.cellZones().findZoneID(set.name()); // skip the excluded set if (set.name() == excludeSetName) { continue; } if (zoneID == -1) { Info<< nl << "Operating on set " << set.name() << endl; } else { Info<< nl << "Operating on set/zone " << set.name() << endl; } if (verbose) { Info<< " " << set.type() << " " << set.name() << " now size " << returnReduce(set.size(), sumOp<label>()) << endl; } labelList sourceCells(set.size()); label nNewCells = 0; forAll(set.toc(), i) { label cellI = set.toc()[i]; // mirror cell centroid's position and find corresponding cell scalar alpha = mirrorPlane.normalIntersect ( cellCenters.internalField()[cellI], mirrorPlane.normal() ); label newCellI = mesh.findCell(cellCenters.internalField()[cellI] + 2.0*alpha*mirrorPlane.normal()); sourceCells[nNewCells] = newCellI; nNewCells++; } // add found cells to current cellSet dictionary sourceDict01; sourceDict01.name() = "sourceInfo"; sourceDict01.set("value", sourceCells); autoPtr<topoSetSource> sourceCellSet = topoSetSource::New ( "labelToCell", static_cast<polyMesh&>(mesh), sourceDict01 ); sourceCellSet().applyToSet(topoSetSource::NEW, set); if (verbose) { Info<< " " << set.type() << " " << set.name() << " now size " << returnReduce(set.size(), sumOp<label>()) << nl << endl; } set.sync(mesh); set.write(); // add cells to cellZone if (zoneID > -1) { // read cellZoneSet autoPtr<topoSet> currentZone = topoSet::New ( "cellZoneSet", static_cast<polyMesh&>(mesh), set.name() ); if (verbose and currentZone.valid()) { Info<< " " << currentZone().type() << " " << currentZone().name() << " now size " << returnReduce(currentZone().size(), sumOp<label>()) << endl; } // build source topoSet dictionary sourceDict; sourceDict.name() = "sourceInfo"; sourceDict.set("set", mesh.cellZones()[zoneID].name()); autoPtr<topoSetSource> source = topoSetSource::New ( "setToCellZone", static_cast<polyMesh&>(mesh), sourceDict ); // add the source to current zone source().applyToSet(topoSetSource::ADD, currentZone()); if (verbose and currentZone.valid()) { Info<< " " << currentZone().type() << " " << currentZone().name() << " now size " << returnReduce(currentZone().size(), sumOp<label>()) << endl; } currentZone().sync(mesh); currentZone().write(); } } Info<< "End\n" << endl; return 0; } Somehow, the pretty formatting got lost in copy&paste. |
October 6, 2022, 13:20 |
Rep Power: 8 |
Thanks you! Sounds good
I would love to try that. The code is actually pretty blown up . Would you mind to append the original file? |
