[Other] Starting Toposet Rotor Grid at an Angle |
April 20, 2017, 12:24 |
NJ
So I have a grid that consists of a rotor toposet inside of a stator. I would like to know if I can specify an angle for the rotor grid to start at, (right now it starts horizontally). I have tried varying the origin and amplitude in dynamicMeshDict but haven't been able to get it to work. Is there an easy way to set the grid to start at a specified angle rather than having to figure out how to redraw it? Also, if anyone knows how to specify an alpha value for angular acceleration here instead of a constant angular velocity, that would also help! ignore the old headers Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh solidBodyMotionFvMesh; motionSolverLibs ( "libfvMotionSolvers.so" ); solidBodyMotionFvMeshCoeffs { cellZone rotor; solidBodyMotionFunction oscillatingRotatingMotion; //rotatingMotion; oscillatingRotatingMotionCoeffs //rotatingMotionCoeffs { origin (0 0 0); //axis (0 0 1); amplitude (0 0 -85); omega 0.296706; // rad/s } } // ************************************************************************* // |
dynamic mesh, rotatemesh, toposet |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 8, 2024 00:17 |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 03:39 |
big difference between clockTime and executionTime | LM4112 | OpenFOAM Running, Solving & CFD | 21 | February 15, 2019 04:05 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
Normal vector, slope and aspect angle | g_niro | Main CFD Forum | 0 | February 2, 2011 18:24 |
