[Other] How to convert .raw file into .dat file
Old   April 17, 2017, 10:59
Default How to convert .raw file into .dat file
zhangzhizheng
lisics is on a distinguished road
Hi all,
I want to convert .raw file into .dat(binary) file under linux or using some openfoam utilities,but I have no idea until now. I have tried "imageFileConvert" utility,it's useful but can only convert .dat file into .raw file.So I want to know if there is some methods converting .raw file into .dat file using openfoam or other tools under linux.
Thanks in advance!
lisics
lisics is offline   Reply With Quote
Old   April 17, 2017, 12:43
zhangzhizheng
I am sorry for my careless that I misunderstanded the usage of "imageFileConvert" utility before.I just convert .raw file into .dat file successfully using "imageFileConvert" utility by typing "imageFileConvert header_file input_file.raw output_file.dat" in terminal.Sorry again.
Old   January 12, 2018, 13:31
Chayanit Nigaltia
CHAYANIT is on a distinguished road
How to do it.Please tell me also?
CHAYANIT is offline   Reply With Quote
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
