[Salome] Salome, sliding interface and "Zero length edge detected." |
April 14, 2017, 17:41 |
Oskar
Rep Power: 11 |
Dear All.
I'm trying to do simulation of Internal Combustion Engine in openFoam 1.6 ext: https://www.cfd-online.com/Forums/openfoam/83177-engine-simulation-mesh-motion-topological-changes-5.html#post308624 There is a working 2D example of mesh. I can reproduce similar 2D mesh with Salome and run it without problems: https://www.youtube.com/watch?v=jVls41R8j_c Unfortunately when I create 3D mesh and try to run simulation following error appears: "FOAM FATAL ERROR : Zero length edge detected. Probable projection error: slave patch probably does not project onto master." Has anyone of You faced similar problem? Have a nice day to all of You! sheaker |
