[Other] exceeds capacity of label fatal error, how to recompile with a larger data type? |
Abe
Rep Power: 10 ![]() |
Hello Foamers,
I am trying to make a fairly large mesh, and I am getting the error: exceeds capability of label (2147483647). Please recompile with larger datatype for label. [40] [40] From function Foam::globalIndex::globalIndex(Foam::label) [40] in file meshes/polyMesh/globalMeshData/globalIndex.C at line 86. [40] FOAM parallel run exiting I am guessing that 2147483647 is the largest value of int 32 on the 64 bit cluster I am using, and that the cell index is beyond that (please correct if that is wrong). So my question is, how do I fix this? 160 cores of old hardware overloaded the label in less than 3 hours, so maybe I am interpreting this wrong? On a related note, I am also beyond the largest value for maxGlobalCells in snappyHexMeshDict - if I try to increase it, snappy gives an error that it expected int 32. Int 32 just seems too small - or more likely, I am doing something wrong. Help! Thanks |
activeBaffleVelocity boundary condition ? | om3ro | OpenFOAM Programming & Development | 10 | November 16, 2020 23:26 |
multiphaseEulerFoam/tank discharge | ves | OpenFOAM Running, Solving & CFD | 8 | December 31, 2017 14:59 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
