[mesh manipulation] createBaffles from surface also adds extra faces |
Roger
Rep Power: 9 ![]() |
Dear Users,
I am trying to use createBaffles with an stl file. For which the Dict is below. The resulting baffle however also takes some of the small boundary layer faces inside it, making the baffle have fences of sorts. Is there a posibility to make the searchableSurface use a sort of tolerance or something like that? I've also tried to first make the faceSet/faceZoneSet with topoSet (see attached) but this also puts the first faces of the BL cells in the set. Kind regards, Roger Last edited by Coenstra; March 31, 2017 at 09:42. Reason: incomplete |
createbaffles |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
