[snappyHexMesh] unsymmetric boundary layer extrusion on simple symmetric geometry
Old   March 28, 2017, 09:23
Default unsymmetric boundary layer extrusion on simple symmetric geometry
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hello all,
I am preparing a simple pipe simulation using snappy. Even though the geometry is a simple open pipe, snappy can not extrude boundary layers on the walls near the inlet. If I choose different refinement levels and boundary layer final thickness, it gets either better, or worse.
Is this normal? If not, what am I doing wrong?
|       o          |                                                          |
|    o     o       | HELYX-OS                                                  |
|   o   O   o      | Version: v2.4.0                                           |
|    o     o       | Web:     http://www.engys.com                            |
|       o          |                                                          |
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object snappyHexMeshDict;
    castellatedMesh true;
    snap true;
    addLayers true;
    geometry
        inner_wrap.stl
            type triSurfaceMesh;
            name inner_wrap;
            appendRegionName false;
        external_walls.stl
            name external_walls;
        edge_wall.stl
            name edge_wall;
        internal_walls.stl
            name internal_walls;
        INLET.stl
            name INLET;
        cylinder_vr5
            type searchableCylinder;
            point1 ( 0.0 -0.5 0.28 );
            point2 ( 0.0 0.55 0.28 );
            radius 0.2;
        cylinder_vr6
            point1 ( 0.0 -0.3 0.28 );
            point2 ( 0.0 0.5 0.28 );
            radius 0.08;
        cylinder_vr4
            point1 ( 0.0 -1.0 0.28 );
            point2 ( 0.0 0.6 0.28 );
            radius 0.5;
        cylinder_vr3
            point1 ( 0.0 -2.0 0.28 );
            point2 ( 0.0 0.8 0.28 );
            radius 1.0;
        cylinder_vr2
            point1 ( 0.0 -3.0 0.28 );
            point2 ( 0.0 1.0 0.28 );
            radius 2.0;
        cylinder_vr1
            point1 ( 0.0 -5.0 0.28 );
            point2 ( 0.0 1.5 0.28 );
            radius 3.0;
    castellatedMeshControls
        features
            file "external_walls_line.eMesh";
            levels ((0.0 6));
            refineFeatureEdgesOnly false;
            file "edge_wall_line.eMesh";
            levels ((0.0 9));
            file "internal_walls_line.eMesh";
            levels ((0.0 7));
            file "INLET_line.eMesh";
            levels ((0.0 7));
        refinementSurfaces
            external_walls
                level ( 0 0 );
            edge_wall
                level ( 8 8 );
            internal_walls
                level (7 7 );
            INLET
                level ( 7 7 );
        refinementRegions
            inner_wrap
                mode inside;
                levels (( 1E5 7 ));
            edge_wall
                mode distance;
                levels (( 0.01 8 ) ( 0.05 7 ) ( 0.1 6 ) );
            cylinder_vr5
                mode inside;
                levels (( 1E5 5 ));
            cylinder_vr6
                mode inside;
                levels (( 1E5 6 ));
            cylinder_vr4
                mode inside;
                levels (( 1E5 4 ));
            cylinder_vr3
                mode inside;
                levels (( 1E5 3 ));
            cylinder_vr2
                mode inside;
                levels (( 1E5 2 ));
            cylinder_vr1
                mode inside;
                levels (( 1E5 1 ));
        locationInMesh ( 0.0 0.0 1.0 );
        maxLocalCells 1000000;
        maxGlobalCells 20000000;
        minRefinementCells 0;
        nCellsBetweenLevels 5;
        resolveFeatureAngle 30.0;
        allowFreeStandingZoneFaces true;
        planarAngle 30.0;
        maxLoadUnbalance 0.1;
    snapControls
        nSolveIter 300;
        nSmoothPatch 5;
        tolerance 5.0;
        nRelaxIter 8;
        nFeatureSnapIter 80;
        implicitFeatureSnap true;
        explicitFeatureSnap true;
        multiRegionFeatureSnap true;
    addLayersControls
        layers
            external_walls
                nSurfaceLayers 5;
                expansionRatio 1.25;
                finalLayerThickness 0.8;
            edge_wall
                 nSurfaceLayers 5;
            internal_walls
                nSurfaceLayers 5;
        relativeSizes true;
        expansionRatio 1.2;
        finalLayerThickness 0.6;
        minThickness 0.0001;
        nGrow 0;
        featureAngle 240.0;
        slipFeatureAngle 80.0;
        nRelaxIter 5;
        nSmoothSurfaceNormals 1;
        nSmoothNormals 3;
        nSmoothThickness 10;
        maxFaceThicknessRatio 0.5;
        maxThicknessToMedialRatio 0.3;
        minMedialAxisAngle 90;
        nBufferCellsNoExtrude 0;
        nLayerIter 50;
        nRelaxedIter 20;
        writeVTK false;
        noErrors false;
        layerRecovery 1;
        growZoneLayers false;
        projectGrownUp 0.0;
    meshQualityControls
        maxNonOrtho 65.0;
        maxBoundarySkewness 20;
        maxInternalSkewness 4;
        maxConcave 80.0;
        minFlatness 0.5;
        minVol 1.0E-13;
        minTetQuality 1.0E-15;
        minArea -1.0;
        minTwist 0.02;
        minDeterminant 0.001;
        minFaceWeight 0.05;
        minVolRatio 0.01;
        minTriangleTwist -1.0;
        nSmoothScale 4;
        errorReduction 0.75;
        relaxed
            maxNonOrtho 75;
    debug 0;
    mergeTolerance 1.0E-6;
    autoBlockMesh false;
Attesz is offline   Reply With Quote
Old   April 25, 2017, 08:13
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
I think that is quite common problem.
Snappy is not very competent for making boundary layers in corners or in complex geometry.
KaLium is offline   Reply With Quote
boundary layer, snappy hex mesh
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Questions about Boundary Layer Thickness and Turbulence Models famerfamer STAR-CCM+ 3 July 12, 2012 10:47
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
