March 20, 2017, 12:01 |
Problem with SnappyHexMesh
Joe-Hin Yip
Hi Foamers, i got a problem to do a mesh without to delete my Inlet and Outlet..
after the command to mesh with SHM, ge gonna delete all my "zero-sized-patches", which is my outlet, inlet and other walls Thanks everyone for help ! This is the log and down below the dict from Snappy patch faces layers overall thickness [m] [%] ----- ----- ------ --- --- ein 5121 2.63 0.000316 83.6 aus 0 0 0 0 kammer 628 2.77 0.000329 87 diff 0 0 0 0 Removing zero-sized patches: maxY type patch at position 0 minX type patch at position 1 maxX type patch at position 2 minY type patch at position 3 minZ type patch at position 4 maxZ type patch at position 5 inlet type wall at position 6 aus type wall at position 9 diff type wall at position 11 Layer mesh : cells:24817 faces:79720 points:30432 SnappyHexmeshDict /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; // make basic mesh ? snap true; // decide to snap back to surface ? addLayers true; // decide to add viscous layers ? geometry // Load in STL files here { inlet.stl {type triSurfaceMesh; name inlet;} outlet.stl {type triSurfaceMesh; name outlet;} ein.stl {type triSurfaceMesh; name ein;} aus.stl {type triSurfaceMesh; name aus;} kammer.stl {type triSurfaceMesh; name kammer;} diff.stl {type triSurfaceMesh; name diff;} ding.stl {type triSurfaceMesh; name ding;} refinementBox {type searchableBox; min (-0.1 -0.1 -0.05); max ( 0.1 0.1 0.05);} }; castellatedMeshControls { maxLocalCells 1000000; //max cells per CPU core maxGlobalCells 2000000; //max cells to use before mesh deletion step minRefinementCells 10; //was 0 - zero means no bad cells are allowed during refinement stages maxLoadUnbalance 0.10; nCellsBetweenLevels 1; // expansion factor between each high & low refinement zone // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command ( {file "inlet.eMesh"; level 3;} {file "outlet.eMesh"; level 3;} {file "ein.eMesh"; level 3;} {file "aus.eMesh"; level 3;} {file "kammer.eMesh"; level 3;} {file "diff.eMesh"; level 3;} ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ refinementSurfaces // Surface-wise min and max refinement level { inlet {level (0 0);} outlet {level (0 0);} ein {level (3 3);} aus {level (5 5);} // was 4 4 kammer{level (5 5);} // was 4 4 diff{level (5 5);} // was 4 4 } resolveFeatureAngle 80; // Resolve sharp angles // Default 30 refinementRegions // In descending levels of fine-ness {volume {mode distance; levels ((0.0006 4) (0.002 3) (0.01 2));}} // was ((0.001 4) (0.003 3) (0.01 2)) locationInMesh (0 0 0); //to decide which side of mesh to keep ** allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 3; tolerance 4.0; nSolveIter 30; nRelaxIter 5; nFeatureSnapIter 15; // default is 10 // New settings from openfoam 2.2 onwards for SHMesh implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract explicitFeatureSnap true; // default is true multiRegionFeatureSnap false; // deafault is false - detects features between multiple surfaces } // Settings for the layer addition. addLayersControls //add the PATCH names from inside the STL file so STLpatchName_insideSTLName { relativeSizes false; // was true layers { ein {nSurfaceLayers 3;} // was 3 aus {nSurfaceLayers 3;} // was 3 kammer {nSurfaceLayers 3;} // was 3 diff {nSurfaceLayers 3;} // was 3 } expansionRatio 1.3; finalLayerThickness 0.00016; //was 0.00016 minThickness 0.00008; //was 0.00008 nGrow 0; // was 1 // Advanced settings featureAngle 80; // was 70 //- When not to extrude surface. 0 is flat, 90 is right angle. nRelaxIter 3; //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh. nSmoothSurfaceNormals 1; // Number of smoothing iterations of surface normals nSmoothNormals 3; // Number of smoothing iterations of interior mesh movement direction nSmoothThickness 10; // Smooth layer thickness over surface patches maxFaceThicknessRatio 0.5; // Stop layer growth on highly warped cells maxThicknessToMedialRatio 0.3; // Reduce layer growth where ratio thickness to medial distance is large minMedianAxisAngle 130; // Angle used to pick up medial axis points nBufferCellsNoExtrude 0; // Create buffer region for new layer terminations nLayerIter 50; // Overall max number of layer addition iterations } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minFlatness 0.5; minVol 1e-13; minTetQuality 1e-9; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.02; minVolRatio 0.01; minTriangleTwist -1; // Advanced nSmoothScale 4; errorReduction 0.75; } // Advanced debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1E-6; // ************************************************** *********************** // Last edited by Joehin; March 21, 2017 at 05:39. Reason: wrong |
March 27, 2017, 11:48 |
Rep Power: 13 |
Weird... see if the size of those patches are not too small even with refinement.
Se Urso Vires Foge Tocando Gaita Para Hamburgo |
March 27, 2017, 12:21 |
Joe-Hin Yip
i solved my problem, my blockMesh was to small
Thank your anyway for help |
imgonnadie, locationinmesh, snappyhexmesh 3d |
[snappyHexMesh] Problem with decomposePar, snappyHexMesh | luca1992 | OpenFOAM Meshing & Mesh Conversion | 12 | August 23, 2017 20:06 |
[snappyHexMesh] snappyHexMesh problem | cfdsolver1 | OpenFOAM Meshing & Mesh Conversion | 0 | June 23, 2016 11:09 |
[snappyHexMesh] Problem handling with subdictionary in SnappyHexMesh | Lorenzo92 | OpenFOAM Meshing & Mesh Conversion | 0 | November 21, 2015 14:57 |
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model | Saideep | OpenFOAM Meshing & Mesh Conversion | 5 | May 10, 2015 15:46 |
[snappyHexMesh] Problem with snappyHexMesh | giack | OpenFOAM Meshing & Mesh Conversion | 2 | September 18, 2014 11:03 |
