[Other] Terrain point cloud to watertight surface |
March 13, 2017, 07:32 |
Rep Power: 16 |
Hi all,
is someone here working with terrain point clouds and preparing them for meshing with snappyHexMesh or cfMesh? I am trying to figure out the best workflow in developing watertight surfaces ready for CFD simulation. Ofcourse when you have terrain data you have to be able to add boundaries above the terrain to close your model. It is really about being able to import the point cloud into CAD software as a point cloud or in another format. The best thing, as far as I know, is to create NURBS from your point cloud and work with that in the 3D design software. That would be much more lightweight than going for STL surfaces or similar. All comments appreciated. |
March 15, 2017, 08:49 |
Point cloud to the watertight surface mesh
Neither snappyHexMesh nor cfMesh require a watertight surface to perform volume meshing. cfMesh requies a domain to look closed such that it can distinguish between the outside and the volume than shall be filled with cells. Have you ever considered using PCL library (http://pointclouds.org) or MeshLabl (http://www.meshlab.net/) to generate a triangulated surface from a point cloud? To close the domain you can generate a cylinder surface mesh or a box surface mesh, merge it with the terrain mesh, and remove the face below the terrain. That is enough for meshing with cfMesh.
Principal Developer of cfMesh and CF-MESH+ www.cfmesh.com Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram |
March 27, 2017, 11:38 |
Rep Power: 16 |
Thank you Franjo for your answer. My domain has irregular outside border and I was able to extract that out of the model. Then I could copy it to a distance above the original border and loft a surface between those profiles. Then I filled the top border with a flat surface. I came to these cocnlusing using your idea.
Thank you. Sent from my SM-G920F using CFD Online Forum mobile app |
March 28, 2017, 11:12 |
#4 | |
Paulo Vatavuk
Rep Power: 18 |
Which program do you recommend to close the domain? Paulo |
[snappyHexMesh] snappyHexMesh generates not planar surface | krzychu111 | OpenFOAM Meshing & Mesh Conversion | 2 | April 23, 2020 16:38 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 04:59 |
Normal - Helical Surface | m. malik | Main CFD Forum | 3 | February 3, 2006 12:56 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
How to determine a point is inside a tetrahedral? | G.P. Xia | Main CFD Forum | 16 | January 12, 2000 11:15 |
