March 10, 2017, 16:46 |
Chaotic sHM layering
badoumba
Rep Power: 13 |
Hi people!
I am struggling to get my layers properly meshed in a complex geometry. - picture a shows some weird bridges in the middle of...nothing. - picture b shows no creation of layers at corners all even with featureAngle set to 180. Here are my sHM settings Code:
castellatedMeshControls { maxLocalCells 10000000; maxGlobalCells 2000000; minRefinementCells 10; maxLoadUnbalance 0.10; nCellsBetweenLevels 5; features ( { file "verso.eMesh"; level 8; } ); refinementSurfaces { verso_wall { level (6 7); patchInfo { type wall; } } } resolveFeatureAngle 60; refinementRegions { verso_wall { mode distance; levels ((0.1 6)(0.25 5)); } ... } Code:
addLayersControls { relativeSizes false; layers { verso_wall { nSurfaceLayers 10; } } expansionRatio 1.3; firstLayerThickness 0.0002; //finalLayerThickness 0.5; //thickness 0.01; minThickness 0.0002; nGrow 0; featureAngle 180; slipFeatureAngle 80; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; } |
March 15, 2017, 18:59 |
Joachim Herb
Rep Power: 22 |
Are you sure, that what you see are not artifacts of paraview? In the settings before actually reading the file, uncheck the split polyhedral setting.
March 15, 2017, 21:01 |
Rep Power: 25 |
I'm not really sure about the bridge, that looks odd, never seen anything like that.
However I would highly recommend these two things: 1. Use relative sizes for the prism mesh. They are much more robust. 2. Avoid changing surface sizes on a single surface - if you can force the surface to be all one size or over 2 sizes snappy has an easier time making prisms. |
March 16, 2017, 08:02 |
badoumba
Rep Power: 13 |
@jherb
I don't have the screenshot here but I double checked the view settings in paraView. Didn't change anything. @me3840 I like to have absolute size for the layers to keep a very precise control as I am running a Low-Re simulation (the layers covering the boundary layer and the first layer according to the targeted y+) I agree for the consistent size over a surface. cfMesh is working this way and the layers are now perfect. KateEisenhower suggested gmsh to be even more accurate. But I have very dense stl files and the GUI of gmsh can hardly support it on my laptop. |
March 16, 2017, 08:08 |
Rep Power: 12 |
Hi all,
Just for the record, I didn't say that gmsh is more accurate than cfMesh. Only for the models I am simulating, I think it's easier to create a structured mesh with gmsh than deal with the layers in cfMesh. Sorry if there was a misunderstanding in our PMs. Best regards; Kate |
March 16, 2017, 08:14 |
badoumba
Rep Power: 13 |
No problem, my apologies.
[snappyHexMesh] different sHM results on same geometry when everythin is in one or several stl-files. | Laika | OpenFOAM Meshing & Mesh Conversion | 1 | September 8, 2016 05:09 |
[snappyHexMesh] 2D AMI Moving Mesh with sHM; How hard can this be? | ADGlassby | OpenFOAM Meshing & Mesh Conversion | 18 | June 18, 2013 07:07 |
[snappyHexMesh] SHM: feature edge snapping not conforming | thab | OpenFOAM Meshing & Mesh Conversion | 3 | November 26, 2012 15:04 |
[snappyHexMesh] troubles with sHM and parallel | Tobi | OpenFOAM Meshing & Mesh Conversion | 1 | August 30, 2012 18:54 |
[snappyHexMesh] Multi Region Meshing with sHM | marango | OpenFOAM Meshing & Mesh Conversion | 3 | March 27, 2012 01:51 |
