[Commercial meshers] meshconversion from ansys to openfoam format.
Old   March 9, 2017, 14:42
Default meshconversion from ansys to openfoam format.
Manu Chakkingal
manuc is on a distinguished road
Hello
I would like to use mesh generated in ANSYS workbench for the solver
chtMultiRegionFoam,
What do I need
Generate two solid geometries disconnected in a fluid domain.
What did I try
Generated mesh in ansys workbench after combining the geometry into a part while exporting geometry into the meshing section.
what do I see
I get a geometry with only a single fluid solid interface , though I have two solids in contact with fluid. both solids are considered together and thus forms a single solid-fluid coupling interface.
Thus I cant give different boundary conditions at solid walls , seprately for the solid bodies.
what else did I try
Without converting into part while making geometry, I get required number of contact regions.
Now I dont have any guarrentee that the solid fluid interface mesh is coupled properly.
When I convert it into a .cas or .msh file and convert into OF readable format, it shows error showing the grid points in the solid and the nearby fluid region which is in contact with the solid are not equal in number. Thus fails in the initial mesh conversion stage itself.
(It works fine for a single soid in fluid domain)
What help do I need
1. Any method to create coupled interfaces i.e ways to form multiple parts. solid 1 with fluid1 (part1) solid2 with fluid1 (part2) or
2. Any other coupling method between solid and fluid which I could use to ensure the fluid and soid region in contact have same grid points.
3. Does any of the native meshers support the conversion and coupling from ANSYS mesh
Thanks in advance
Regards
Manu
manuc is offline   Reply With Quote
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
