[Commercial meshers] Import geometry from AnsysMeshing with multi block
Old   January 31, 2017, 05:39
Post Import geometry from AnsysMeshing with multi block
Julien P
Ptiji is on a distinguished road
Good morning,
I have a problem maybe with the conversion of mesh. It is imported from Ansys Meshing.
Here is my mesh :
As you can see, there are interfaces in the fluid-interior. To correct this problem, I modified the end of file .msh :
b74b b7a2 b776 15d45 0
b72c b7a1 b799 1676e 0
b796 b7a2 b72f 15c90 0
(12 (2 1 4337d 1 2))
(45 (1 interior interior-solide)())
(45 (2 fluid solide)())
(45 (5 wall wall)())
(45 (6 symmetry symmetryplane)())
(45 (7 pressure-outlet outlet)())
(45 (8 velocity-inlet inlet)())
(45 (9 pressure-outlet outletwater)())
(45 (10 interface zone_de_contact-src)())
(45 (11 interface zone_de_contact-trg)())
(45 (12 interface zone_de_contact_2-src)())
(45 (13 interface zone_de_contact_2-trg)())
(45 (14 interface zone_de_contact_3-src)())
(45 (15 interface zone_de_contact_3-trg)())
(45 (16 interface zone_de_contact_4-src)())
(45 (17 interface zone_de_contact_4-trg)())
(0 Variables:)
(37 (
(sliding-interfaces (
(zone_de_contact(sb1-id 10) (sb2-id 11) (interior-id 0) (bnd1-id 0) (bnd2-id 0) (periodic . #f) (coupled . #f) (face-periodic . #f))
(zone_de_contact_2(sb1-id 12) (sb2-id 13) (interior-id 0) (bnd1-id 0) (bnd2-id 0) (periodic . #f) (coupled . #f) (face-periodic . #f))
(zone_de_contact_3(sb1-id 14) (sb2-id 15) (interior-id 0) (bnd1-id 0) (bnd2-id 0) (periodic . #f) (coupled . #f) (face-periodic . #f))
(zone_de_contact_4(sb1-id 16) (sb2-id 17) (interior-id 0) (bnd1-id 0) (bnd2-id 0) (periodic . #f) (coupled . #f) (face-periodic . #f))
by
And after I convert the file thanks to
fluentMeshToFoam file.msh
After that I modified boundary for my problem (after check patch name on paraview):
//6
5
    wall
        type            wall;
        inGroups        1(wall);
        nFaces          16430;
        startFace       534639;
    symmetryplane
        type            symmetryPlane;
        inGroups        1(symmetryPlane);
        nFaces          6198;
        startFace       551069;
    outlet
        type            patch;
        nFaces          129;
        startFace       557267;
    inlet
        type            patch;
        nFaces          129;
        startFace       557396;
    outletwater
        type            wall;
        inGroups        1(wall);
        nFaces          124;
        startFace       557525;
//    default_wall
//        type            wall;
//        inGroups        1(wall);
//        nFaces          9012;
//        startFace       557649;
I checked and corrected the name of patch on every file in folder 0.
After that I ran simpleFoam and I have this message :
User@user:~/OpenFOAM-in-Box-16.10/OpenFOAM-3.0.x/tutorials/incompressible/simpleFoam/boitier_maillagefin2$ simpleFoam
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 3.0.x-4b5e129783d9
Exec   : simpleFoam
Date   : Jan 31 2017
Time   : 10:02:16
Host   : "julien-X556UQK"
PID    : 2980
Case   : /home/julien/OpenFOAM-in-Box-16.10/OpenFOAM-3.0.x/tutorials/incompressible/simpleFoam/boitier_maillagefin2
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p     tolerance 0.01
    field U     tolerance 0.001
    field "(k|epsilon|omega|f|v2)"     tolerance 0.001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
No MRF models present
No finite volume options present
Starting time loop
streamLine streamLines:
    automatic track length specified through number of sub cycles : 5
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libpthread.so.0"
#3  Foam::polyMeshTetDecomposition::findFaceBasePts(Foam::polyMesh const&, double, bool) at ??:?
#4  Foam::polyMesh::tetBasePtIs() const at ??:?
#5  Foam::Cloud<Foam::passiveParticle>::initCloud(bool) at ??:?
#6  Foam::passiveParticleCloud::passiveParticleCloud(Foam::polyMesh const&, Foam::word const&, bool) at ??:?
#7  Foam::uniformSet::calcSamples(Foam::DynamicList<Foam::Vector<double>, 0u, 2u, 1u>&, Foam::DynamicList<int, 0u, 2u, 1u>&, Foam::DynamicList<int, 0u, 2u, 1u>&, Foam::DynamicList<int, 0u, 2u, 1u>&, Foam::DynamicList<double, 0u, 2u, 1u>&) const at ??:?
#8  Foam::uniformSet::genSamples() at ??:?
#9  Foam::uniformSet::uniformSet(Foam::word const&, Foam::polyMesh const&, Foam::meshSearch const&, Foam::dictionary const&) at ??:?
#10  Foam::sampledSet::addwordConstructorToTable<Foam::uniformSet>::New(Foam::word const&, Foam::polyMesh const&, Foam::meshSearch const&, Foam::dictionary const&) at ??:?
#11  Foam::sampledSet::New(Foam::word const&, Foam::polyMesh const&, Foam::meshSearch const&, Foam::dictionary const&) at ??:?
#12  Foam::streamLine::read(Foam::dictionary const&) at ??:?
#13  Foam::streamLine::streamLine(Foam::word const&, Foam::objectRegistry const&, Foam::dictionary const&, bool) at ??:?
#14  Foam::OutputFilterFunctionObject<Foam::streamLine>::allocateFilter() at ??:?
#15  Foam::OutputFilterFunctionObject<Foam::streamLine>::start() at ??:?
#16  Foam::functionObjectList::read() at ??:?
#17  Foam::Time::loop() at ??:?
#18  Foam::simpleControl::loop() at ??:?
#19  ? at ??:?
#20  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#21  ? at ??:?
Erreur de segmentation (core dumped)
I don't know if the mistakes are from the importation of mesh or from the solving.
I already did a solving with the same geometry but with only one block and I didn't have problem.
Sorry for my English (I'm french). Please use easy words to answer .
Thank you
Ptiji is offline   Reply With Quote
msh multiblock interface
[Other] 3D geometry exported from Mimics, import to OpenFOAM seuchsy OpenFOAM Meshing & Mesh Conversion 2 October 5, 2016 09:58
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[DesignModeler] problem with import geometry from catia pavilion ANSYS Meshing & Geometry 1 November 23, 2012 11:45
[ICEM] Best way to import geometry ICEM Cottbus ANSYS Meshing & Geometry 4 June 12, 2012 10:42
[DesignModeler] Import external geometry problem Houman ANSYS Meshing & Geometry 0 May 16, 2012 05:24
