[Commercial meshers] Problems with Mesh, Altair Hypermesh to FOAM |
January 21, 2017, 06:46 |
Matthias H
Hi Community,
I'm new to this forum and didn't want to ask for your help, cause there are so many threads having almost similar issues. But this one is special, so now it's definitely time to ask. Introduction My main goal is to simulate a laminar, incompressible flow of resin through a very little cell (20x15mm). Pic1 Within the cell (cavity) there are rovings. These are consideres as walls with zero porosity. Pic2 Structure I'm having the following structure in Hypermesh before export to OpenFoam. ----------------------- inlet (type face, pic 1: green face) outlet (type face, pic 1: bright green face) walls (type face, in pic 1+2: red cavity + colored rovings) fluid (type solid) ----------------------- First of all, is this structure correct? The fluid of type solids fills out the holes (empty space) btw. the rovings in the internal field. Hypermesh doesn't complain about that setting. No error at all! Setting -simpleFoam algorithm -laminar, incompressible -Boundaries: Inlet 2bar, Outlet 0bar; velocities not given - zeroGradient Error checkMesh -allTopology log Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.x-acc2a7707ea6 Exec : checkMesh -allTopology Time : 22:20:46 Host : "uc1n262.localdomain" PID : 29287 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Enabling all (cell, face, edge, point) topology checks. Time = 0 Mesh stats points: 2522342 faces: 6630654 internal faces: 5684580 cells: 2052539 faces per cell: 6 boundary patches: 3 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 2052539 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. <<Writing 9737 cells with zero or one non-boundary face to set oneInternalFaceCells <<Writing 25090 cells with two non-boundary faces to set twoInternalFacesCells *Number of regions: 2670 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 (point connected) with 2047241 cells to cellSet region0 <<Writing region 1 (point connected) with 3 cells to cellSet region1 <<Writing region 2 (point connected) with 2 cells to cellSet region2 <<Writing region 3 (point connected) with 11 cells to cellSet region3 <<Writing region 4 (point connected) with 1 cells to cellSet region4 <<Writing region 5 (fully disconnected) with 2 cells to cellSet region5 <<Writing region 6 (fully disconnected) with 2 cells to cellSet region6 [...] till last region: <<Writing region 2669 (point connected) with 27 cells to cellSet region2669 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 8991 9390 ok (non-closed singly connected) outlet 9923 11912 ok (non-closed singly connected) walls 927160 893087 multiply connected (shared edge) <<Writing 41975 conflicting points to set nonManifoldPoints Checking geometry... Overall domain bounding box (-0.0041 -0.0025 -5e-05) (0.01555 0.01395 0.0011) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.86932e-19 2.16764e-18 -2.07891e-16) OK. Max cell openness = 1.65436e-16 OK. Max aspect ratio = 1 OK. Minimum face area = 2.5e-09. Maximum face area = 2.5e-09. Face area magnitudes OK. Min volume = 1.25e-13. Max volume = 1.25e-13. Total volume = 2.56567e-07. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.71396e-13 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
[...] Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.001 field U tolerance 0.0001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar No MRF models present No finite volume options present Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0899429, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0466972, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.054899, No Iterations 1 [5] #0 [0] #0 [1] #0 [2] #0 [3] #0 [4] #0 Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)-------------------------------------------------------------------------- A process has executed an operation involving a call to the "fork()" system call to create a child process. Open MPI is currently operating in a condition that could result in memory corruption or other system errors; your job may hang, crash, or produce silent data corruption. The use of fork() (or system() or other calls that create child processes) is strongly discouraged. The process that invoked fork was: Local host: [[43444,1],0] (PID 29304) If you are *absolutely sure* that your application will successfully and correctly survive a call to fork(), you may disable this warning by setting the mpi_warn_on_fork MCA parameter to 0. -------------------------------------------------------------------------- at ??:? at ??:? at ??:? [4] #1 Foam::sigFpe::sigHandler(int) at ??:? [5] #1 Foam::sigFpe::sigHandler(int)[1] #1 Foam::sigFpe::sigHandler(int)[0] #1 Foam::sigFpe::sigHandler(int) at ??:? at ??:? [3] #1 Foam::sigFpe::sigHandler(int)[2] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #2 ? at ??:? [5] #2 ? at ??:? [4] #2 ? at ??:? [1] #2 ? at ??:? [2] #2 ? at ??:? [3] #2 ? in "/usr/lib64/libc.so.6" in "/usr/lib64/libc.so.6" [0] #3 Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&)[5] #3 Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) in "/usr/lib64/libc.so.6" in "/usr/lib64/libc.so.6" [...] Summarized: Mesh is not fine (but: no complaints by Hypermesh while exporting, checkMesh okay), solver is exploding while calculating pressure. Second cluster gives same error msg: Code:
Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0208945, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0523874, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0648027, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = nan, No Iterations 1000 time step continuity errors : sum local = nan, global = -nan, cumulative = -nan ExecutionTime = 54.97 s ClockTime = 55 s -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD with errorcode 1. [...] I've tested many configurations. This case scenario works with a very simple (and therefore different) mesh (only cavity) on two independent clusters. Would be that nice, if somebody could give support. Working on this case since 3 weeks, without helpful outcome. Greetings, Matthias |
altair, hypermesh, hyperworks, mesh, openfoam |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
