[blockMesh] checkMesh Failed
Old   January 17, 2017, 10:19
Default checkMesh Failed
Kai Müller
Kev10 is on a distinguished road
Hello everybody,
At first sorry for my bad english :P
I´m new in OpenFoam and have some problems with blockMesh (checkMesh). I tried to create a rectangle with hex in the blockMeshDict. When i run blockMesh, ididn´t get any failed message, but if i run checkMesh, then i get 4 failed message and i don´t know why.
Maybe someone can help me to understand my mistake ?
Best regards Kev10
Kev10 is offline   Reply With Quote
Old   January 20, 2017, 04:42
Antimony is on a distinguished road
Your mesh fails the checkMesh test because your mesh is essentially defined inside out. Based on the way you have defined your mesh, there is a clash between the direction you have specified for the 3rd axis and what you get from the right hand rule.
One simple solution would be to define vertices 0 to 3 with z = -1000 (currently what you have defined as 500) and vertices 4 to 7 with z = 500 (what you currently have as -1000). Essentially switch the vertices around and your mesh should be OK
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   January 22, 2017, 14:43
Kai Müller
Thank you very much Antimony, now it works !!
Best regards
Kev
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 16:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
