[Gmsh] Degenerate 2D Elements when using ElmerSolver |
January 12, 2017, 10:42 |
Mustafa Iqbal
Hello!
I previously posted on the Elmer forum to seek help on this issue, and was told that my issue lies in GMSH. I am generating a mesh which is very fine at a certain point, when I load this mesh into ElmerSolver and run the solver I get degenerate element errors. On reconverting the Elmer mesh to GMSH .msh and investigating, I see those degenerate elements. Please see attached the .msh before input to Elmer, and the .msh after I convert it back from the Elmer format. Here is the .geo code: Code:
//+ Point(1) = {0, 0, 0, 1.0}; //+ Point(3) = {0, 11.45, 0, 1.0}; //+ Point(4) = {0, 22.9, 0, 1.0}; //+ Point(6) = {0.5, 0, 0, 1.0}; //+ Point(7) = {0.75, 0, 0, 1.0}; //+ Point(8) = {0.75, 22.9, 0, 1.0}; //+ Line(1) = {4, 3}; //+ Line(3) = {1, 6}; //+ Line(4) = {6, 7}; //+ Line(5) = {7, 8}; //+ Line(6) = {8, 4}; //+ Line(7) = {3, 6}; //+ Line(8) = {4, 3}; //+ Line(17) = {3, 1}; //+ Line Loop(9) = {8, 7, 4, 5, 6}; //+ Plane Surface(10) = {9}; //+ Characteristic Length {6, 7, 8, 4} = 0.1; //+ Characteristic Length {3} = 10e-6; //+ Physical Line(11) = {8}; //+ Physical Line(12) = {6}; //+ Physical Line(13) = {5}; //+ Physical Line(14) = {4}; //+ Physical Line(15) = {7}; //+ Physical Surface(16) = {10}; //+ Mustafa. |
mesh degenerate 2d elmer |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 06:53 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 06:31 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
Penetrating elements in extruded mesh | Michael P | CFX | 2 | May 20, 2005 09:06 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
