November 29, 2016, 22:31 |
Wing Flap Mesh - BlockMesh
Rep Power: 10 |
Hello Everyone,
I am facing a few problems when trying to mesh my NACA 0009 airfoil with a plain/slotted wing flap using blockMesh. The exact problem entails highly skewed cells in the interface between the circular gap (between the foil and flap) and the outbound rectangular box (I am using a C-type mesh). I tried defining various blocks and manipulating the vertices around, but no luck so far. Please find attached my blockMesh file, as well as, a picture of the problem. Your help is much appreciated. It is currently failing 2 mesh checks, I suspect they are both related to the high skewness involved. Khaled |
block mesh, skewed cells, wing flap |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 13:42 |
Dynamic mesh, hinged flap | Randre | FLUENT | 37 | August 9, 2014 11:40 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
