[blockMesh] Cannot create mesh due to errors in topology, exiting !
Old   November 24, 2016, 06:41
Default Cannot create mesh due to errors in topology, exiting !
Kairo is on a distinguished road
Hi, I'm relative new to OpenFOAM and trying to create a mesh.
The checkMesh says the mesh is ok, but when I try to run blockMesh I get the following error message:
Creating block mesh from
"/home/caelinux/Desktop/OpenFOAM/Eksamen/vonKarman/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
--> FOAM Warning :
From function bool Foam::blockMesh::blockLabelsOK(...)
in file blockMesh/blockMeshCheck.C at line 179
out-of-range point label 92 (max = 47) in block 9
Creating topology patches
--> FOAM FATAL ERROR:
From function blockMesh::createTopology(IOdictionary&)
in file blockMesh/blockMeshTopology.C at line 568.
FOAM exiting
Any help is appreciated, thank you
Kairo is offline   Reply With Quote
Old   November 28, 2016, 12:46
cutter is on a distinguished road
please read http://www.cfd-online.com/Forums/ope...-get-help.html and provide a minimal example (blockMeshDict) that allows to reproduce the problem in order to maximize your chances to get useful help.
The tool checkMesh needs to be run after the mesher (in you case blockMesh) in order to check the newly created mesh for quality and consistency. Since blockMesh fails you're probably running checkMesh against a mesh that was created with a previous setup (before changes in blockMeshDict).
Cutter
cutter is offline   Reply With Quote
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
