[snappyHexMesh] Snappyhex mesh: poor inlet mesh |
November 23, 2016, 05:41 |
Lasse Brams Vinther
Rep Power: 11 |
Hello snappyhexzmeshers, I am currently experiencing an issue when geneating a mesh for a complex geometry of a catalytic burner, with respect to the inlet of the domain.
The issue is shown in the attached figures, and increasing the mesh density doedsn't improve the issue, it only persists in the same areas of the geometry. The domain is a quarter of the real system, where the straight parts of the inlet is symmetry planes and the circular part is a wall. The code for the snappyhexmesh and blockmesh directories are shown below: I know that the refinementsurfaces and refinementregions are quite low and I have tried increasing them up a cell count of 8millions, the currentmesh is around 1million cells. It should be noted that the blockmesh z boundary cuts off the top of the stl files, such that the air inlet patch is cut off as the air inlet mesh didn't improve the resulting velocity. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; // make basic mesh ? snap true; // decide to snap back to surface ? addLayers true; // decide to add viscous layers ? geometry // Load in STL files here { inair.stl {type triSurfaceMesh; name inair;} out.stl {type triSurfaceMesh; name out;} ref_remain.stl {type triSurfaceMesh; name ref_remain;} burnout.stl {type triSurfaceMesh; name burnout;} mono.stl {type triSurfaceMesh; name mono;} swirl.stl {type triSurfaceMesh; name swirl;} sym.stl {type triSurfaceMesh; name sym;} inpipe.stl {type triSurfaceMesh; name inpipe;} refinementBox { type searchableBox; min (0.02 0.03 0.05); max (0.1 0.11 0.3); } }; castellatedMeshControls { maxLocalCells 4000000; //max cells per CPU core maxGlobalCells 16000000; //max cells to use before mesh deletion step minRefinementCells 0; //was 0 - zero means no bad cells are allowed during refinement stages maxLoadUnbalance 0.10; nCellsBetweenLevels 3; // expansion factor between each high & low refinement zone was 2 // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command ( {file "inair.eMesh"; level 3;} {file "out.eMesh"; level 3;} {file "ref_remain.eMesh"; level 3;} {file "burnout.eMesh"; level 3;} {file "mono.eMesh"; level 3;} {file "swirl.eMesh"; level 3;} {file "inpipe.eMesh"; level 3;} {file "sym.eMesh"; level 3;} ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ refinementSurfaces // Surface-wise min and max refinement level { inair {level (0 0);} out {level (0 0);} ref_remain {level (1 1);} // was 3 3 burnout {level (1 1);} // was 3 3 mono {level (1 1);} // was 3 3 swirl {level (3 3);} // was 3 3 inpipe {level (3 3);} // was 3 3 sym {level (0 0);} } resolveFeatureAngle 80; // Resolve sharp angles // Default 30 was 80 // refinementRegions // In descending levels of fine-ness // {volume {mode distance; levels ((0.0006 4) (0.002 3) (0.01 2));}} // was ((0.001 4) (0.003 3) (0.01 2)) // This is combined with the nSmoothPatch, with the nSmoothPatch describing the amount of cells inbetween the refinement levels refinementRegions { refinementBox { mode inside; // inside; levels ((1E15 1)); //1E15 4 } } locationInMesh (0.085 0.1 0.21); //to decide which side of mesh to keep ** allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 5; //should be 5 was 3 //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 5.0; //was 4.0 //- Number of mesh displacement relaxation iterations. nSolveIter 50; //Recomended (typically 30-100) //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; //This specifies the maximum number of relaxing iterations to remove bad cells or mesh points. The relaxing process will stop immediately when the specified number of iterations are done even if the mesh still has bad cells. Thus, higher values will ensure better mesh quality but be more time consuming recommended 8 was 5 //- Highly experimental and wip: number of feature edge snapping // iterations. Leave out altogether to disable. // Do not use here since mesh resolution too low and baffles present nFeatureSnapIter 15; // default is 10 // New settings from openfoam 2.2 onwards for SHMesh implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract explicitFeatureSnap true; // default is true multiRegionFeatureSnap false; // deafault is false - detects features between multiple surfaces important when working with heat transfer between fluid and solid } // Settings for the layer addition. addLayersControls //add the PATCH names from inside the STL file so STLpatchName_insideSTLName { relativeSizes true; // was true layers { ref_remain {nSurfaceLayers 3;} // was 3 burnout {nSurfaceLayers 3;} // was 3 mono {nSurfaceLayers 3;} // was 3 swirl {nSurfaceLayers 3;} // was 3 inpipe {nSurfaceLayers 4;} // was 3 } expansionRatio 1.3; // was 1.1 finalLayerThickness 0.2; //was 0.00016 minThickness 0.01; //was 0.00008 nGrow 0; // was 1 // Advanced settings featureAngle 180; //set 80 was 70 //- When not to extrude surface. 0 is flat, 90 is right angle. was 180 nRelaxIter 3; //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh. nSmoothSurfaceNormals 5; // Number of smoothing iterations of surface normals was 1, recommended 4-5 nSmoothNormals 3; // Number of smoothing iterations of interior mesh movement direction slipFeatureAngle 70; nSmoothThickness 10; // Smooth layer thickness over surface patches maxFaceThicknessRatio 0.5; // Stop layer growth on highly warped cells maxThicknessToMedialRatio 0.3; // Reduce layer growth where ratio thickness to medial distance is large minMedianAxisAngle 130; // Angle used to pick up medial axis points was 130 recommendend 90 nBufferCellsNoExtrude 0; // Create buffer region for new layer terminations nLayerIter 50; // Overall max number of layer addition iterations } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 180; //65; maxBoundarySkewness 20; //20 4 maxInternalSkewness 4; //8 3 maxConcave 80; //80 minFlatness 0.5; minVol 1e-13; minTetQuality -1e+30; //was 1e-15 minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.05; // was 0.02 minVolRatio 0.01; minTriangleTwist -1; // Advanced nSmoothScale 4; //number of error distribution iterations (typically 4). errorReduction 0.75; //amount to scale back displacement at error points (typically 0.75). } // Advanced debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1E-6; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; // does nothing in this case, 0.1 would shrink it by 10x vertices // (x y z) ( (0.02 0.03 0.05) // was 0.02 0.03 0.05 (0.1 0.03 0.05) // was 0.1 0.03 0.05 (0.1 0.11 0.05) // was 0.1 0.11 0.05 (0.02 0.11 0.05) // was 0.02 0.11 0.05 (0.02 0.03 0.26) // was 0.02 0.03 0.3 0.02 0.03 0.26 (0.1 0.03 0.26) // was 0.1 0.03 0.3 0.1 0.03 0.26 (0.1 0.11 0.26) // was 0.1 0.11 0.3 0.1 0.11 0.26 (0.02 0.11 0.26) // was 0.02 0.11 0.3 0.02 0.11 0.26 ); blocks ( hex (0 1 2 3 4 5 6 7) (24 24 75) simpleGrading (1 1 1) //was 16 16 50 ); edges ( ); patches //copied from DICAT shm example "M3_mixing elbow1" ( patch maxY ( (3 7 6 2) ) patch minX ( (0 4 7 3) ) patch maxX ( (2 6 5 1) ) patch minY ( (1 5 4 0) ) patch minZ ( (0 3 2 1) ) patch maxZ ( (4 5 6 7) ) ); mergePatchPairs ( ); // ************************************************************************* // iteration 150, yscale upper limit of 31.6 iteration 150 rescaled, yscale upper limit of 3.09e+2 Thanks for your help in advance. Please let me know if additional information is necessary. Last edited by Swagga5aur; November 23, 2016 at 08:12. |
December 3, 2016, 17:59 |
Lasse Brams Vinther
Rep Power: 11 |
I found a solution to my issue, which was due to defining both pressure and velocity at the inlet patch, where its recommended to specify Dirichlet boundary conditions at two different patches, further explained in another post on the forum:
http://www.cfd-online.com/Forums/ope...ible-flow.html |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) | shubham jain | ANSYS Meshing & Geometry | 1 | April 10, 2017 06:03 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
