[Gmsh] having difficulties with easy GMSH periodics problem
Old   November 22, 2016, 08:51
Default having difficulties with easy GMSH periodics problem
Jack
Jack001 is on a distinguished road
Hi all, I have a presumably simple problem with GMSH involving specifying a periodic surface pair. Here is the code to create the error:
Point(1) = {1.34722, 1.19955, 0, 0.1};
Point(2) = {0.747222, 1.19955, 0, 0.1};
Point(3) = {0, 0.55, 0, 0.1};
Point(4) = {-0.4, 0.55, 0, 0.1};
Point(5) = {1.34722, 0.0995502, 0, 0.1};
Point(6) = {0.747222, 0.0995502, 0, 0.1};
Point(7) = {0, -0.55, 0, 0.1};
Point(8) = {-0.4, -0.55, 0, 0.1};
Line(1) = {1,5};
Line(2) = {5:8};
Line(3) = {8,4};
Line(4) = {4:1};
Line Loop(101) = {1, 2, 3, 4};
Plane Surface(201) = {101};
surfaceVector[] = Extrude {0, 0, 0.25} {Surface {201};Layers{1};Recombine;};
Periodic Surface surfaceVector[5] {208,-206,-217,4} = surfaceVector[3] {209,204,-213,-2};
Physical Volume('internal') = {1};
I get
Error   : Was not able to find corresponding node 5 for periodic connection of surface 214 to 222 using the specified transformation
Any ideas? Many thanks!
Jack001 is offline   Reply With Quote
gmsh, periodic bc
Connectivity problem with grids created using gmsh shank19 SU2 3 May 10, 2017 09:54
problem in GMSH Bharath Bhushan CFD Freelancers 1 April 17, 2017 15:34
[Gmsh] problem in transfiniting the volume in gmsh Bharath Bhushan OpenFOAM Meshing & Mesh Conversion 0 March 30, 2017 09:41
FLUENT boundary condition problem with gmsh EIvb FLUENT 0 April 30, 2013 08:45
A realy easy variable - problem wernsen OpenFOAM Programming & Development 3 January 7, 2013 14:25
