[snappyHexMesh] error checkMesh after run snappyHexMesh |
November 18, 2016, 16:51 |
Mousa Hemmati
Rep Power: 10 |
Hello. i run blockMesh, and checkMesh is ok. but after run the snappyHexMesh -overwrite the che checkMesh is not ok, and 5 error is taken. please help me,
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 135138 faces: 330617 internal faces: 283767 cells: 98704 faces per cell: 6.22451 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 87765 prisms: 1008 wedges: 0 pyramids: 0 tet wedges: 54 tetrahedra: 0 polyhedra: 9877 Breakdown of polyhedra by number of faces: faces number of cells 5 172 6 2256 7 1530 8 120 9 4541 10 1 11 1 12 1114 15 114 18 28 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology w-inlet 258 348 ok (non-closed singly connected) outlet 258 348 ok (non-closed singly connected) atmosphere 399 536 ok (non-closed singly connected) walls 325 441 ok (non-closed singly connected) Front 15118 16452 ok (non-closed singly connected) Back 13924 15041 ok (non-closed singly connected) Spillway_profile3 16568 18353 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (510.5 853.32 0) (514.5 856.5 0.3) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-3.8561e-17 -1.06038e-16 1.37107e-14) OK. ***Open cells found, max cell openness: 0.5, number of open cells 36 <<Writing 36 non closed cells to set nonClosedCells <<Writing 9110 cells with high aspect ratio to set highAspectRatioCells ***Zero or negative face area detected. Minimum area: 0 <<Writing 18868 zero area faces to set zeroAreaFaces Min volume = 2e-300. Max volume = 0.000120907. Total volume = 3.22843. Cell volumes OK. Mesh non-orthogonality Max: 180 average: 28.9768 *Number of severely non-orthogonal faces: 3599. ***Number of non-orthogonality errors: 21337. <<Writing 24936 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 93 faces are incorrectly oriented. <<Writing 93 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 1.67617e+298, 1477 highly skew faces detected which may impair the quality of the results <<Writing 1477 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 5 mesh checks. End |
November 18, 2016, 18:16 |
Arsalan
Rep Power: 12 |
Hi Mousa,
It seems there is something wrong with your snappyHexMeshDict, please provide the output of snappy command ( snappyHexMesh &> log.snappy) and your snappyHexMeshDict. I think the mesh quality controls option is set to relax in your snappyHexMeshDict. Regards, Arsalan. |
November 19, 2016, 01:29 |
error checkMesh after snappyHexMesh
Mousa Hemmati
Rep Power: 10 |
Hi Arasalan. Tank's for answer. snappyHexMesh &> log.snappy as fallows:
Create time Create mesh for time = 0 Read mesh in = 1.34 s Overall mesh bounding box : (510.5 853.32 0) (514.5 856.5 0.3) Relative tolerance : 1e-06 Absolute matching distance : 5.11883e-06 Reading refinement surfaces. Read refinement surfaces in = 0.01 s Reading refinement shells. Read refinement shells in = 0 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 0 s Reading features. Read features in = 0 s Determining initial surface intersections ----------------------------------------- Edge intersection testing: Number of edges : 330617 Number of edges to retest : 330617 Number of intersected edges : 10308 Calculated surface intersections in = 2.02 s Initial mesh : cells:98704 faces:330617 points:135138 Cells per refinement level: 0 27792 1 4445 2 30290 3 36177 Adding patches for surface regions ---------------------------------- Patch Type Region ----- ---- ------ Spillway: 6 wall Spillway_profile3 Added patches in = 0.01 s Selecting decompositionMethod none Refinement phase ---------------- Found point (511 855 0.1) in cell 13570 on processor 0 Surface refinement iteration 0 ------------------------------ Marked for refinement due to surface intersection : 0 cells. Marked for refinement due to curvature/regions : 256 cells. Determined cells to refine in = 0.64 s Selected for refinement : 256 cells (out of 98704) hexRef8 : Dumping cell as obj to "/home/mosa/Desktop/phdt1/cell_79157.obj" --> FOAM FATAL ERROR: cell 79157 of level 2 uses more than 8 points of equal or lower level Points so far:8(43971 51028 53963 59172 115160 115161 115163 115165) From function hexRef8::setRefinement(const labelList&, polyTopoChange&) in file polyTopoChange/polyTopoChange/hexRef8.C at line 3743. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Foam::hexRef8::setRefinement(Foam::List<int> const&, Foam:olyTopoChange&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libdynamicMesh.so" #3 Foam::meshRefinement::refine(Foam::List<int> const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libautoMesh.so" #4 Foam::meshRefinement::refineAndBalance(Foam::strin g const&, Foam::decompositionMethod&, Foam::fvMeshDistribute&, Foam::List<int> const&, double) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libautoMesh.so" #5 Foam::autoRefineDriver::surfaceOnlyRefine(Foam::re finementParameters const&, int) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libautoMesh.so" #6 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, bool, Foam::dictionary const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libautoMesh.so" #7 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/snappyHexMesh" #8 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #9 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/snappyHexMesh" |
November 19, 2016, 04:37 |
Arsalan
Rep Power: 12 |
well, snappyHexMesh has failed and nothing could be said with these low details.
Please provide your sHMDict and a whole description of geometry, also with blockMeshDict. Regards, Arsalan. |
November 19, 2016, 06:33 |
error checkMesh ofter snappyHexMeshDict
Mousa Hemmati
Rep Power: 10 |
Hi.
Geometry is steeped spillway. I guess the snappyHexMeshDict isnot set god. then i offered snappyHexMeshDict, BlockMeh, stl file, and iamage paraview. best wishes |
November 20, 2016, 03:42 |
Error checkmesh ofter run snappyhexmeshdict
Mousa Hemmati
Rep Power: 10 |
Hi.
Fortunately, the error was resolved. Stl files had not plotted in the origin. |
[snappyHexMesh] Snappyhexmesh parallel run - 2D mesh-motion error | Vignesh2508 | OpenFOAM Meshing & Mesh Conversion | 3 | May 19, 2021 05:12 |
[swak4Foam] and snappyHexMesh gives erratic mesh result | Coke Rivas Ordenes | OpenFOAM Community Contributions | 3 | April 17, 2017 14:06 |
User fortran to input/output file in a parallel run | doublestrong | CFX | 5 | March 31, 2017 09:15 |
Motorbike tutorial for snappyhexmesh taking forever to run? | massive_turbulence | OpenFOAM Running, Solving & CFD | 0 | April 27, 2014 03:00 |
OpenMPI fails cluster run with an orphaned IP Address | svg | OpenFOAM Running, Solving & CFD | 0 | January 28, 2014 04:41 |
