[snappyHexMesh] How to add layers on the whole geometry surface
Old   November 16, 2016, 17:10
Exclamation How to add layers on the whole geometry surface
meithid is on a distinguished road
Hi FOAMERS,
I find I can't add the layers on the whole geometry surface. In some region, the surface is not extruded for layers insertion.
In the first figure, the geometry surface is a bare cylinder. SHM can add the layers all over the surface successfully. In the second figure, SHM failed to add the layers in some corner regions. I try to tune FeatureAngle to some big value (300 degrees), but it didn't help.
Is there any way to do that the layers can be added for the second geometry surface.
MANY THANKS.
meithid is offline   Reply With Quote
Old   January 24, 2017, 06:41
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi meithid, did you solve this issue?
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 10:23
[snappyHexMesh] Layers in snappy collapse in some places of my solid Yuby OpenFOAM Meshing & Mesh Conversion 0 March 8, 2015 16:44
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
