[Commercial meshers] fluent mesh conversion to foam |
November 14, 2016, 06:57 |
sangram
Rep Power: 12 |
Hello Everyone,
I am trying to import mesh (.msh file) from fluent to OpenFoam. When I enter command "fluentMeshToFoam", I am getting following error. I am using chtMultiRegionSimpleFaom solver. Need help.. Thanks in advance. --> FOAM FATAL IO ERROR: wrong token type - expected int, found on line 0 the punctuation token ')' file: IStringStream.sourceFile at line 0. From function operator>>(Istream&, int&) in file primitives/ints/int/intIO.C at line 69. FOAM exiting |
November 14, 2016, 07:14 |
sangram
Rep Power: 12 |
I got the solution in one of my older posts. I did not get it As I was using OpenFoam after long time.
Here is the solution: Please follow this way: workbench Mesh: tool - option - meshing- export - ansys fluent - format of input file - ascii |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
[Commercial meshers] Thin Walls Conversion from Fluent Mesh | Isaac | OpenFOAM Meshing & Mesh Conversion | 1 | March 4, 2016 12:08 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
