[Other] Structured mesh around airfoil
Like Tree6Likes
Old   March 4, 2021, 03:26
Mikko
Flowkersma is on a distinguished road
Is the mesh fine after those steps? If you want to further split the wall boundary, you can use topoSet utility.
Best, Mikko
Flowkersma is offline   Reply With Quote
Old   March 4, 2021, 05:18
afa13 is on a distinguished road
Hi Miikko,
I ran checkMesh and i got the following:
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    internal points:  0
    faces:            98853
    internal faces:   49053
    cells:            24651
    faces per cell:   6
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     24651
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    walls               249      498      ok (non-closed singly connected)
    frontAndBack        49302    49800    ok (non-closed singly connected)
    farfield            249      498      ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-11.6194 -13.4897 0) (13.607 13.4897 1)
    Mesh has 2 geometric (non-empty/wedge) directions (1 1 0)
    Mesh has 2 solution (non-empty) directions (1 1 0)
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (-4.78455e-20 -8.4208e-18 -7.00152e-15) OK.
    Max cell openness = 1.42909e-14 OK.
    Max aspect ratio = 536.007 OK.
    Minimum face area = 2.64583e-09. Maximum face area = 1.54076.  Face area magnitudes OK.
    Min volume = 2.64583e-09. Max volume = 0.585316.  Total volume = 537.939.  Cell volumes OK.
    Mesh non-orthogonality Max: 15.2625 average: 5.14365
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.375565 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
Then I checked the yPlus and I got the following:
Create time
Create mesh for time = 0
SIMPLE: Convergence criteria found
        p: tolerance 0.1
        U: tolerance 0.001
        "(k|epsilon)": tolerance 0.01
Time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
    RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     on;
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              0;
    sigmak          1;
    sigmaEps        1.3;
No MRF models present
No finite volume options present
yPlus yPlus write:
    writing object yPlus
    patch walls y+ : min = 0.0799493, max = 0.0808106, average = 0.0807724
Time = 57
Reading field p
Reading field U
RAS
    RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     on;
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              0;
    sigmak          1;
    sigmaEps        1.3;
yPlus yPlus write:
    patch walls y+ : min = 0.214267, max = 11.3621, average = 1.23938
End
I am still new at openFoam. So i'm not familiar with all the commands. I followed your instructions to create a mesh from construct2D and generate it in openFoam. Can you please tell me how to split the farfield patch into an inlet and outlet patches step by step, because i used the help option of topoSet and I didnt know what to do next?
Thanks!
afa13 is offline   Reply With Quote
Old   March 6, 2021, 06:59
Mikko
The mesh has a high (geometric) quality. Why do you want to split the farfield boundary (see inletOutlet boundary condition that I mentioned in one of the previous messages)? Where exactly would you split the farfield patch?
Old   March 6, 2021, 10:33
Hi Mikko,
I was just trying to understand how to split the faces and how to identify them in the code and assigning them to patches by playing around. It has nothing to do with my goal that is to simulate the flow around the airfoil and determine the lift and drag coefficients.
Can you check if my boundary conditions are ok?
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      epsilon;
epsilonInlet  3.61; // Cmu^0.75 * k^1.5 / L ; L =10
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform $epsilonInlet;
boundaryField
 farfield
        type            freestreamPressure;
        freestreamValue $internalField;
        value           $internalField;
    walls
        type            epsilonWallFunction;
    frontAndBack
        type            empty;
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.2;
boundaryField
 farfield
    walls
        type            kqRWallFunction;
    frontAndBack
        type            empty;
|  \\    /   O peration     | Version:  5.x                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (51.7844 5.52501 0);
boundaryField
    walls
        type            noSlip;
     farfield
        type            freestreamVelocity;
    frontAndback
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      p;
internalField   uniform 0;
boundaryField
    walls
        type            zeroGradient;
     farfield
    frontAndback
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 1.94e-05;
boundaryField
    walls
        type            nutkWallFunction;
     farfield
    frontAndback
        type            empty;
Old   March 7, 2022, 18:14
jose daniel
hoyos98 is on a distinguished road
I suggest you visit https://aeroptimal.com/mesh (you must create an account to use this module), where you can create a full structured airfoil mesh - https://youtu.be/4Opu0zk7gFk . You can export .su2 .msh .foam .vtk
hoyos98 is offline   Reply With Quote
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
Volume mesh for Cyclone separator Rajan Pointwise & Gridgen 17 May 4, 2014 06:38
[snappyHexMesh] How to Do External Mesh for Airfoil sHM msuaeronautics OpenFOAM Meshing & Mesh Conversion 1 September 23, 2012 05:00
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
