Christian Jähnel
Rep Power: 9 ![]() |
Hey Foamers,
I'm pretty new here, but already have some trouble with SHM. It's about adding layers in edges, I have an edge between two .stl geometries, on which I add 3 Layers. But as it comes close to the edge, the layers are collapsing. How can I add layers right into the edge? I already tried to make one .stl file out of these two, the result was even worse. I already played a bit the feature angle. Maybe someone can help me here? Thanks in Advance! Chris |
add layers, addlayercontrols, feature angle, snappyhexmesh 3d, snappyhexmeshdict |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
multiRegionHeater error | ordinary | OpenFOAM Running, Solving & CFD | 2 | June 9, 2020 17:43 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
conjugateHeatFoam + interFoam | farhagim | OpenFOAM Programming & Development | 15 | July 19, 2016 07:55 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
