[Commercial meshers] Fluent to foam indexing issue
Old   October 29, 2016, 01:27
Default Fluent to foam indexing issue
Josh Dawson
JMDag2004 is on a distinguished road
OF: OF-2.3.0
Situation: Compiled fluentDataToFoam in 2.3.0. I import .msh file without issues. Import .dat file and the face is indexing methodology in Fluent is apparently different than OF. The internal cells come over very clean but the boundary faces (i.e walls, inlet, outlet) have inconsistencies with how the face ids are indexed. So I get what appears to be a random distribution of hydro variable face values. Slicing the domain in oaraview reveals a perfect transformation of the internal call values. Probably something Fluent is doing to make it difficult to use these tools. Was curious if someone has run across this issue or knew of a fix. I could write a code to re-arrange the variable arrays in the input files but a nudge in the direction of OFs face indexing methodology would be greatly appreciated.
JMDag2004 is offline   Reply With Quote
Old   October 30, 2016, 21:56
Antimony is on a distinguished road
I am not sure if this will work, but out of curiosity I ask: have you tried renumberMesh after you imported the mesh into OF?
And perhaps just run createPatch with a createPatchDict used to remove empty patches?
Cheers,
Antimony
Antimony is offline   Reply With Quote
boundary, face values, fluent to openfoam, indexing
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
SimpleFoam cannot open include file Marija OpenFOAM Running, Solving & CFD 1 October 28, 2020 11:35
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
