October 8, 2016, 13:09 |
SnappyHexMesh Patch Problem
Deutschland
Rep Power: 10 |
Hey everbody,
I`struggleing with snappyhexmesh. There must be a problem with the patches, however I have no idea where. I created my stl-files by exporting groups from salome. Attched you can see the checkMesh-reply and the sHMD. I would appreciate if someone could give me advise. Great regards On the one hand I get /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.0-665f1db4c1f1 Exec : checkMesh Date : Oct 08 2016 Time : 18:05:34 Host : "albrecht-cae-CELSIUS-M720" PID : 6446 Case : /home/albrecht_cae/Schreibtisch/OpenFoam/20160924_valve nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 618285 faces: 1700663 internal faces: 1595529 cells: 541479 faces per cell: 6.0873866 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 500090 prisms: 20856 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 20533 Breakdown of polyhedra by number of faces: faces number of cells 5 622 6 3305 9 11371 12 4209 15 961 18 65 Checking topology... ****Problem with boundary patch 0 named inlet of type wall. The patch should start on face no 1595529 and the patch specifies 1595531. Possibly consecutive patches have this same problem. Suppressing future warnings. ***Boundary definition is in error. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 894 990 ok (non-closed singly connected) outlet 820 899 ok (non-closed singly connected) patchwall 103418 103722 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.0099956077 -0.032523782 -0.0099985384) (0.02 0.002504085 0.0099985384) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-6.785461e-16 4.0906973e-15 3.3559227e-15) OK. Max cell openness = 4.1354321e-16 OK. Max aspect ratio = 5.7326472 OK. Minimum face area = 2.773767e-09. Maximum face area = 4.6502648e-07. Face area magnitudes OK. Min volume = 8.4842851e-13. Max volume = 1.9190422e-10. Total volume = 2.5154271e-06. Cell volumes OK. Mesh non-orthogonality Max: 51.877025 average: 7.5311999 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.6908976 OK. Coupled point location match (average 0) OK. Mesh OK. End And the sHMD: FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; // make basic mesh ? snap true; // decide to snap back to surface ? addLayers false; // decide to add viscous layers ? geometry // Load in STL files here { inlet.stl {type triSurfaceMesh; name inlet;} outlet.stl {type triSurfaceMesh; name outlet;} patchwall.stl {type triSurfaceMesh; name patchwall;} completegeometry.stl {type triSurfaceMesh; name completegeometry;} }; castellatedMeshControls { maxLocalCells 1000000; //max cells per CPU core maxGlobalCells 2000000; //max cells to use before mesh deletion step minRefinementCells 10; //was 0 - zero means no bad cells are allowed during refinement stages maxLoadUnbalance 0.1; nCellsBetweenLevels 7; // expansion factor between each high & low refinement zone // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command ( {file "inlet.eMesh"; level 0;} {file "outlet.eMesh"; level 0;} {file "patchwall.eMesh"; level 0;} ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ refinementSurfaces // Surface-wise min and max refinement level { inlet {level (0 0);} outlet {level (0 0);} patchwall {level (2 2);} } resolveFeatureAngle 10; // Resolve sharp angles // Default 30 refinementRegions // In descending levels of fine-ness {completegeometry {mode distance; levels ((0.0002 1) (0.0005 1) (0.01 0));}} // was ((0.001 4) (0.003 3) (0.01 2)) locationInMesh (0 0 -0.007); //to decide which side of mesh to keep ** allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 0; tolerance 4.0; nSolveIter 300; //30 nRelaxIter 10; //5 nFeatureSnapIter 20; // default is 10 // New settings from openfoam 2.2 onwards for SHMesh implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract explicitFeatureSnap true; // default is true multiRegionFeatureSnap false; // deafault is false - detects features between multiple surfaces } // Settings for the layer addition. addLayersControls //add the PATCH names from inside the STL file so STLpatchName_insideSTLName { relativeSizes true; // was true layers { patchwall { nSurfaceLayers 3; } // was 3 } expansionRatio 1.2; finalLayerThickness 0.5; //was 0.00016 minThickness 0.2; //was 0.00008 nGrow 0; // was 1 // Advanced settings featureAngle 180; // was 70 //- When not to extrude surface. 0 is flat, 90 is right angle. nRelaxIter 10; //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh. nSmoothSurfaceNormals 5; // Number of smoothing iterations of surface normals nSmoothNormals 8; // Number of smoothing iterations of interior mesh movement direction nSmoothThickness 10; // Smooth layer thickness over surface patches maxFaceThicknessRatio 0.5; // Stop layer growth on highly warped cells maxThicknessToMedialRatio 0.3; // Reduce layer growth where ratio thickness to medial distance is large minMedianAxisAngle 130; // Angle used to pick up medial axis points nBufferCellsNoExtrude 0; // Create buffer region for new layer terminations nLayerIter 100; // Overall max number of layer addition iterations } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minFlatness 0.5; minVol 1e-13; minTetQuality 1e-9; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.02; minVolRatio 0.01; minTriangleTwist -1; // Advanced nSmoothScale 4; errorReduction 0.75; } // Advanced debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1E-6; |
steadyUniversalMRFFoam Tutorial fails in MixingPlane | HenrikJohansson | OpenFOAM Bugs | 0 | February 14, 2019 05:48 |
Problem in defining patch deformation | paul b | OpenFOAM Programming & Development | 3 | April 27, 2010 01:31 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
