[snappyHexMesh] snappy refuses to mesh ellipsoid (but works for every other shape) |
October 7, 2016, 04:25 |
Lilly
Rep Power: 12 |
Dear Foamers,
I'm working on an external flow around different shapes. I already tried a sphere, a submarine and various others. Every time I used snappyHexMesh for meshing and it worked like a charm. Now, I use the same setup like for the sphere and everything else, I only exchanged the .stl-files. If I run 1) only castellatedMesh: The refinement boxes occur, but no surface refinement. In the log-file I found: Code:
Surface refinement iteration 0 ------------------------------ Marked for refinement due to surface intersection : 0 cells. Determined cells to refine in = 0.02 s Selected for refinement : 0 cells (out of 7680) Stopping refining since too few cells selected. 3) all of it: The layers look awful of course... I used different .stl's from various meshers, I also checked them with Rhino and Blender and found nothing bad. Also, I loaded the blockMesh and stl at the same time in ParaView and the dimensions and position match. Currently I am working with version 2.4.0 (it's not possible to upgrade). Please find my case here: https://www.dropbox.com/s/2p7eukjs69...psoid.zip?dl=0 I would appreciate if somebody could have a look at it and enlighten me :-) Thank you! |
October 7, 2016, 05:12 |
Rep Power: 16 |
Your blockMesh is too coarse and as a result snappy cannot detect the ellipsoid/determine the cells that have to be refined based on ellipsoid stl. Double the number of cells in the x & z directions and you will see it working. Cheers, Antimony |
October 7, 2016, 05:25 |
Lilly
Rep Power: 12 |
Thank you very much for your fast reply.
I will give it a try in some minutes. EDIT: Of course it worked excellently. So new questions pop up in my mind: 1) I understand that the surface refinement orientates towards the initial blockMesh. Thus, refinement boxes won't help here, correct? 2) Is there an approximation/ a ratio for the relation between the dimensions of the body and cell size of the surrounding mesh? I am just wondering, because the sphere I meshed before had nearly the same dimensions. Thank you! Last edited by 5tern; October 7, 2016 at 05:36. Reason: tried suggestion |
October 7, 2016, 05:43 |
Rep Power: 16 |
You are welcome. I am no expert at snappyHexMesh, but I will bravely attempt to answer your questions based on my understanding of it. 1. Refinement boxes mainly focus on refining the cells in a volume. Capturing the surface is mainly done (if I am not wrong) in the feature edge refinement and surface refinement. 2. I don't know any such number, but I would guess roughly at least 4 cells in the vicinity of the geometry will help in detecting the geometry. Cheers, Antimony P.S. The go-to-guide for me for snappyHexMesh is this: http://openfoamwiki.net/images/f/f0/...SlidesOFW7.pdf |
October 7, 2016, 05:52 |
Lilly
Rep Power: 12 |
Thank you! :-)
refinementsurfaces, snappy, snappyhexmesh, surface refinement |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
