[Other] Changing from Fill Bottle to Rinse Bottle |
October 5, 2016, 11:03 |
Warna Downey
Rep Power: 10 |
I have gotten the fill bottle Tutorial of Hassan Hemida to work well for my simulations of pouring lava into water or wet sediments.
Now I would like to turn the bottle over and inject magma into the "bottle". It should be fairly simple for me to invert the mesh but I keep getting an error when I use the blockMesh command. --> FOAM FATAL ERROR: Trying to specify a boundary face 4(2 5 19 16) on the face on cell 1 which is either an internal face or already belongs to some other patch. This is face 0 of patch 0 named inlet. I know it's probably something elementary but since I am just learning all of this I would greatly appreciate the help in getting the mesh right. I think I need to reorder the inlet and wall conditions but I am not sure how to go about it properly. Thanks for your help! /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.4 | | \\ / A nd | Web: http://www.openfoam.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (-50 230 0) (-5 230 0) (5 30 0) (-50 30 0) (5 230 0) (-5 30 0) (50 230 0) (50 30 0) (5 20 0) (-5 20 0) (10 10 0) (-10 10 0) (10 0 0) (-10 0 0) (-50 230 1) (-5 230 1) (5 30 1) (-50 30 1) (5 230 1) (-5 30 1) (50 230 1) (50 30 1) (5 20 1) (-5 20 1) (10 10 1) (-10 10 1) (10 0 1) (-10 0 1) ); blocks ( hex (5 7 6 4 19 21 20 18) (100 200 1) simpleGrading (1 1 1) hex (2 5 4 1 16 19 18 15) (100 200 1) simpleGrading (1 1 1) hex (3 2 1 0 17 16 15 14) (100 200 1) simpleGrading (1 1 1) hex (9 8 5 2 23 22 19 16) (10 200 1) simpleGrading (1 1 1) hex (11 10 8 9 25 24 22 23) (10 20 1) simpleGrading (1 1 1) hex (13 12 10 11 27 26 24 25) (10 20 1) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (2 5 19 16) ) wall inletWall ( (2 9 23 16) (9 11 25 23) (11 13 27 25) (5 8 22 19) (8 10 24 22) (10 12 26 24) ) wall bottleWall ( (6 7 21 20) (7 5 19 21) (3 2 17 16) (3 0 14 17) ) patch atmosphere ( (0 1 15 14) (1 4 18 15) (4 6 20 18) ) empty frontAndBack ( (0 1 2 3) (1 4 5 2) (4 6 7 5) (2 5 8 9) (9 8 10 11) (11 10 12 13) (14 15 16 17) (15 18 19 16) (18 20 21 19) (16 19 22 23) (23 22 24 25) (25 24 26 27) ) ); mergePatchPairs ( ); // ************************************************** *********************** // |
October 5, 2016, 11:40 |
Found Part of my mistake
Warna Downey
Rep Power: 10 |
I mapped the wrong face for the inlet. Changed the patch inlet to
patches ( patch inlet ( (13 12 26 27) ) Now I still have another error --> FOAM FATAL ERROR: Inconsistent number of faces between block pair 1 and 3 From function blockMesh::calcMergeInfo() in file blockMesh/blockMeshMerge.C at line 217. Maybe I can figure this thing out! Again any help is well appreciated |
October 5, 2016, 13:01 |
Error in my vertices
Warna Downey
Rep Power: 10 |
There was an error in my vertices. I finally found it after doing some checking and rechecking.
Here it is in case you want to fill a bottle. The mesh size needs to be changed but all in all it works. /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.4 | | \\ / A nd | Web: http://www.openfoam.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (-50 230 0) (-5 230 0) (-5 30 0) (-50 30 0) (5 230 0) (-5 30 0) (50 230 0) (50 30 0) (5 20 0) (-5 20 0) (10 10 0) (-10 10 0) (10 0 0) (-10 0 0) (-50 230 1) (-5 230 1) (-5 30 1) (-50 30 1) (5 230 1) (-5 30 1) (50 230 1) (50 30 1) (5 20 1) (-5 20 1) (10 10 1) (-10 10 1) (10 0 1) (-10 0 1) ); blocks ( hex (5 7 6 4 19 21 20 18) (10 20 1) simpleGrading (1 1 1) hex (2 5 4 1 16 19 18 15) (10 20 1) simpleGrading (1 1 1) hex (3 2 1 0 17 16 15 14) (10 20 1) simpleGrading (1 1 1) hex (9 8 5 2 23 22 19 16) (10 5 1) simpleGrading (1 1 1) hex (11 10 8 9 25 24 22 23) (10 5 1) simpleGrading (1 1 1) hex (13 12 10 11 27 26 24 25) (10 5 1) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (13 12 26 27) ) wall inletWall ( (2 9 23 16) (9 11 25 23) (11 13 27 25) (5 8 22 19) (8 10 24 22) (10 12 26 24) ) wall bottleWall ( (6 7 21 20) (7 5 19 21) (3 2 17 16) (3 0 14 17) ) patch atmosphere ( (0 1 15 14) (1 4 18 15) (4 6 20 18) ) empty frontAndBack ( (0 1 2 3) (1 4 5 2) (4 6 7 5) (2 5 8 9) (9 8 10 11) (11 10 12 13) (14 15 16 17) (15 18 19 16) (18 20 21 19) (16 19 22 23) (23 22 24 25) (25 24 26 27) ) ); mergePatchPairs ( ); // ************************************************** *********************** // |
August 21, 2017, 08:03 |
Help
Rep Power: 13 |
I am trying the Hameda tutorial u mentioned (water filling bottle) from long back. I am not getting reasonable results. I used inlet velocity as 0.1 m/sec. I am attaching my FOAM files. Please kindly let me know what mistake I am doing. |
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so | immortality | OpenFOAM Pre-Processing | 15 | April 7, 2024 13:35 |
[PyFoam] Problems with the new PyFoam release | zfaraday | OpenFOAM Community Contributions | 13 | December 9, 2014 19:58 |
[PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 08:18 |
Fill a bottle with water for FEA | Jyrator | Main CFD Forum | 0 | September 10, 2013 07:33 |
bottle fill issues | Don | Main CFD Forum | 0 | December 5, 2001 18:42 |
